Hi all,
As probably most of you, I had to find me a distraction during the last “do not leave the house” winter. Since I just setup my small hobbyist electronics lab and also was eager to learn more about woodworking, I did what most average guys would do in this situation - build a boombox
. I decided to use the Dinas Boombox design of 123Toid as a starting point and to adjust it to my needs. The main deviation from the Dinas design was to not use a port but a passive radiator (8.5").
Everything started with a stack of boards, a couple of fullrange speakers from Dayton Audio (4") and a subwoofer from TangBand (6"), and - of course - the Arylic Up2Stream Amp 2.1 for the “inner values”.
The woodworking part was not that complicated - glueing the sides together and covering them with brown structured Tolex, routing holes in front and back for speakers, radiator, and control panel, veneering front and back in Mahogany, and adding a handle, some rubber feet, and cabinet corners to give it a vintage “guitar amp”-ish look. Afterwards, the shell looked like this:
Then, I had the “glorious” idea to unsolder the volume encoder from the Arylic Up2Stream board (to use it in my own control panel) - and failed miserably.
(Without words.)
My kudos to the Arylic engineers for the robust design - the board still worked perfectly with the little flaw that the volume could only be controlled via App or remote control now - since I destroyed the encoder (and some part of the PCB)
Only afterwards I learned that the board has a very handy 9pin breakout connector that allows, beside other things, to connect an external volume control. At least, if you can teach your volume control to provide a voltage impulse of intensity A for “volume down” and intensity B for “volume up”. Unfortunately, none of the volume encoders I know will do this, instead they just return a noisy 2-bit Gray code and let you figure out what they want to tell you. To solve this problem, I used a small microcontroller (ATtiny 85) to decipher the encoder response and convert it to the voltage impulses requested by the Arylic board. I put the encoder (a new one since I broke the original one during my desoldering failure), the microcontroller, and some more electronic components on a small piece of PCB, connected it to the Arylic board and - it worked
This success encouraged me to design a small control panel for the volume control, the mode switch, the mode LEDs (Line In, USB, WiFi, Bluetooth), the power/WPS switch, the Play/Pause and Next buttons, and the infrared sensor. All of these functionalities (and more) are provided by the 9pin breakout connector mentioned. One tip if you also want to use this connector: The Arylic manual just says “PH2.0-9P” but the correct name of the needed female connector is “JST XH 9pin” (pitch 2.54mm). Since crimping these small connectors can be a nightmare I suggest to buy the connector with pre-installed wires.
Here’s the control panel (goes to the front of the boombox), the audio in/out panel, and the power supply panel (later two go to the back). I didn’t find a better (while still affordable) solution than using a two-layer approach. The inner layer is hand-made from 2mm aluminium, the outer layer is laser-cut from 1.5mm acrylic. Unfortunately, the acrylic was not stable enough to use it as only layer.
Now, everything was ready for final assembly. Here’s a picture of the interior of the boombox (with speakers not mounted yet):
In the upper left corner, there is the Arylic Up2Stream Amp 2.1 board. In the lower left corner, there is a DIY relay-based speaker control board. In the upper right corner, there is a Dayton lithium battery board holding five 18650 batteries (not visible because mounted underneath the board). In the lower right corner, there is a DIY power supply distribution board.
After mounting the speakers and screwing on the back, the boombox was finished. Voila
Despite some setbacks (for which I take the blame), it was a pleasure to build my boombox powered by the Arylic Up2Stream Amp 2.1 board. What sets it appart from other amplifier boards I know (beside the ability to adjust its acoustic and control behavior using the ACP Workbench) is the breakout connector that allows you to design your own control panel freely, just based on the space constraints and aesthetic rules, not on the form factor and control layout of the board itself. Kudos for this.
Finally, if I may also express some criticism towards Arylic: For a board that powerful, the manual is definitely to short, leaving out certain aspects especially important for DIY makers. For example, it would be nice to state the correct technical names of all connectors on the board so that you can find the necessary counterparts without trial-and-error.
Hope this presentation of my DIY boombox was of any use to you.
Best regards,
Sven
My build will be little less complicated though.
. They did not work if you added your “own” R47 because this shifted the voltage levels. Although this error is known now it might still be a good idea to put together your control circuit on a breadboard first.
