From Stack of Boards to Boombox (with Up2Stream Amp 2.1)
Just a quick update since there was no reply.
I tested the ADC_Key without the 0.1µF cap in the diagram on a breadboard and it worked for me on U2S AMP2.1. I then added it to my DIY button board and it works there, too. That is for the buttons I am using: Mode, Volume -, Volume +, Mute
Hello,
Great build!
Did you have any problems getting the audio source LEDs (WiFi, BT…) to work correctly? I am finding the WiFi LED and USB LED are not stable. WiFi LED will correctly turn on but eventually the USB LED will also turn on withing a few minutes. I am not using the USB port. Did you run into this issue?
Thanks,
Matty
Hi Matty,
No problems with status LEDs in my build. At any time, only one of the LEDs is turned on. Most of the time, I’m using either the BT or the WiFi mode. Occasionally, the boom box loses the connection and the status has to be reset again. No issues apart from that.
Regards, Sven
Thank you Sven,
I just tried a reset. Same problem. Will keep playing with it. Odd used the 1k resistors and pulled power from PH2.0-9P. LED cathodes connected to pins 3-6.
Anyway, attached is a pic of my build so far. The speakers are transmission line. Sealed cabinet subwoofer.
Thanks again,
Matty
I am having this same issue and now I remember why I don’t use the amp 2.1 and stick to the stereo Amp v3/v4.
The pinout in the connector for LEDs doesn’t seem to work as intended, nor as the users manual indicates. Common anode nor common cathode seem to be adequate. I cannot get either an RGB led nor a set of individual leds to light up unless I solder straight into the individual surface mounted LEDs in the board.
If anyone know wtf is wrong, I’d appreciate the help.
After using the boombox for several years now, I finally took the time to write a much more detailed description on how I built it. It can be found on my own DIY/repair website at https://www.oldstuffstillworks.com/blog/my-boombox/.
