Hello everyone! I need some advice, as I’ve been unable to resolve this issue through customer support. Here’s the situation. I have experience using the Up2Stream Mini board in a vintage radio, where everything was straightforward since the signal from the card went to the radio’s tube amplifier. Now, I have a new project, and I want to install the Up2Stream Amp board in a vintage radio chassis. I would like to control the board using the radio’s original knobs and display visual signals through external lamps. Is it possible to do this with this device? Thank you all for any information.
Welcome! See maybe here : Blaupunkt ca. 1930;
or
Technics SU-V5 with Up2Stream Mini V3 Project
Button Board vs. Touch Board Questions - #4 by Tot
Up2Stream mini v1 / pro 1 / mini v3 / amp v3 problems
Nice Radio, pls more Pic’s from back and inner “Circle” .
