Hello,
When I navigated to the below link, the site responded with an “OK”
http://192.168.10.112/httpapi.asp?command=SetUpdateServer:http://ota.rakoit.com/third
Afterwards, nothing seems to have happened when I opened the 4Stream App on my device (tried both Android and iOS.)
I even tried rebooting the WR320 device to no avail. Also, I tried a factory reset, and updated the API again with the same result.
Is there anything that I’m missing? Can you add my device from the information below please?
{ “language”: “en_us”, “ssid”: “WR320_DF5C”, “hideSSID”: “0”, “SSIDStrategy”: “2”, “firmware”: “3.8.6327”, “build”: “release”, “project”: “Lanzi_4566”, “priv_prj”: “Lanzi_4566”, “Release”: “20181127”, “branch”: “stable/wiimu-3.8”, “group”: “0”, “expired”: “0”, “internet”: “1”, “uuid”: “FF31F0127C6B98649AA428CA”, “MAC”: “00:22:6C:F7:DF:5C”, “STA_MAC”: “00:22:6C:F7:DF:5E”, “date”: “2022:12:03”, “time”: “04:22:50”, “tz”: “-5.000000”, “netstat”: “0”, “essid”: “”, “apcli0”: “0.0.0.0”, “eth2”: “192.168.10.112”, “hardware”: “A31”, “VersionUpdate”: “0”, “NewVer”: “0”, “mcu_ver”: “0”, “mcu_ver_new”: “0”, “dsp_ver_new”: “0”, “ra0”: “10.10.10.254”, “temp_uuid”: “F2D114385C51D491”, “cap1”: “0x1000”, “capability”: “0x80800”, “languages”: “0xe”, “dsp_ver”: “”, “streams_all”: “0x7ffffffe”, “streams”: “0x7ffffffe”, “region”: “unknown”, “external”: “0x0”, “preset_key”: “6”, “plm_support”: “0x6”, “spotify_active”: “0”, “WifiChannel”: “11”, “RSSI”: “0”, “battery”: “0”, “battery_percent”: “0”, “securemode”: “0”, “upnp_version”: “1004”, “upnp_uuid”: “uuid:FF31F012-7C6B-9864-9AA4-28CAFF31F012”, “uart_pass_port”: “8899”, “communication_port”: “8819”, “web_firmware_update_hide”: “0”, “web_login_result”: “-1”, “ignore_talkstart”: “0”, “silenceOTATime”: “”, “ignore_silenceOTATime”: “1”, “iheartradio_new”: “1”, “privacy_mode”: “0”, “user1”: “323:524”, “user2”: “5959:6291”, “DeviceName”: “WR320_DF5C”, “GroupName”: “WR320_DF5C” }
Thanks,
Lamar
