Thank you very much for your fast response and for the firmware file. The manual upgrade worked well!
Would that solution be compatible with Arylic devices in terms of multiroom synchronized play?
Hi, can this device be also upgraded? I am using I2S output to dac board
{ "uuid": "FF31F0125BC9A91754C04805", "DeviceName": "SoundSystem_308A", "GroupName": "SoundSystem_308A", "ssid": "SoundSystem_308A", "language": "en_us", "firmware": "4.6.334447", "hardware": "A31", "build": "release", "project": "Huan_SoundSystem", "priv_prj": "Huan_SoundSystem", "project_build_name": "a31slave_noasr", "Release": "20211103", "temp_uuid": "5914659DC79640EE", "hideSSID": "0", "SSIDStrategy": "0", "branch": "A31_stable_4.6", "group": "0", "wmrm_version": "4.2", "internet": "1", "MAC": "00:22:6C:66:30:8A", "STA_MAC": "00:22:6C:66:30:8C", "ETH_MAC": "00:00:00:00:00:00", "CountryCode": "CN", "CountryRegion": "1", "netstat": "2", "essid": "4E455432345F32", "apcli0": "192.168.2.121", "eth2": "", "ra0": "10.10.10.254", "eth_dhcp": "1", "VersionUpdate": "0", "NewVer": "0", "set_dns_enable": "1", "mcu_ver": "197", "mcu_ver_new": "0", "dsp_ver": "0", "dsp_ver_new": "0", "date": "2023:03:13", "time": "11:49:39", "tz": "1.0000", "dst_enable": "1", "region": "unknown", "prompt_status": "1", "iot_ver": "1.0.0", "upnp_version": "1005", "cap1": "0x1200", "capability": "0x28492000", "languages": "0x6", "streams_all": "0x7ffffffe", "streams": "0x7f9831fe", "external": "0x0", "plm_support": "0x54", "preset_key": "10", "spotify_active": "0", "lbc_support": "0", "privacy_mode": "0", "WifiChannel": "8", "RSSI": "-46", "BSSID": "BC:EE:7B:8E:6C:78", "battery": "0", "battery_percent": "0", "securemode": "1", "auth": "WPAPSKWPA2PSK", "encry": "AES", "upnp_uuid": "uuid:FF31F012-5BC9-A917-54C0-4805FF31F012", "uart_pass_port": "8899", "communication_port": "8819", "web_firmware_update_hide": "0", "ignore_talkstart": "0", "web_login_result": "-1", "silenceOTATime": "", "ignore_silenceOTATime": "1", "new_tunein_preset_and_alarm": "1", "iheartradio_new": "1", "new_iheart_podcast": "1", "tidal_version": "2.0", "service_version": "1.0", "security": "https\/2.0", "security_version": "2.0" }
Am I supposed to use the third server for OTA?
I have got an Up2Stream Pro with 4.6.415145.35 version and others devices with older version.
There is the getStatus response
{ “language”: “en_us”, “ssid”: “Power Dynamics_A239”, “hideSSID”: “1”, “SSIDStrategy”: “2”, “firmware”: “4.2.7312”, “build”: “release”, “project”: “MV_WiFiDemo”, “priv_prj”: “MV_WiFiDemo”, “Release”: “20190812”, “branch”: “stable/wiimu-4.2”, “group”: “0”, “expired”: “0”, “internet”: “1”, “uuid”: “FF31F0126C8B75F9B03096A1”, “MAC”: “00:22:6C:10:A2:39”, “STA_MAC”: “00:22:6C:10:A2:3B”, “CountryCode”: “CN”, “CountryRegion”: “1”, “date”: “2023:03:13”, “time”: “13:54:51”, “tz”: “1.000000”, “dst_enable”: “1”, “netstat”: “2”, “essid”: “4C697665626F782D43413930”, “apcli0”: “192.168.1.13”, “eth2”: “0.0.0.0”, “hardware”: “A31”, “VersionUpdate”: “0”, “NewVer”: “0”, “mcu_ver”: “5”, “mcu_ver_new”: “0”, “dsp_ver_new”: “0”, “ra0”: “10.10.10.254”, “temp_uuid”: “6E600D0FA00D2E8E”, “cap1”: “0x1000”, “capability”: “0x8e86840”, “languages”: “0x6”, “dsp_ver”: “0”, “streams_all”: “0x7ffffffe”, “streams”: “0x7ffffffe”, “region”: “unknown”, “external”: “0x0”, “preset_key”: “10”, “plm_support”: “0x0”, “spotify_active”: “0”, “lbc_support”: “0”, “WifiChannel”: “11”, “RSSI”: “-62”, “battery”: “0”, “battery_percent”: “0”, “securemode”: “0”, “ali_pid”: “EDIFIER_ENTERTAINMENT_ATALK_MA1”, “ali_uuid”: “”, “upnp_version”: “1005”, “upnp_uuid”: “uuid:FF31F012-6C8B-75F9-B030-96A1FF31F012”, “uart_pass_port”: “8899”, “communication_port”: “8819”, “web_firmware_update_hide”: “0”, “web_login_result”: “-1”, “ignore_talkstart”: “0”, “silenceOTATime”: “”, “ignore_silenceOTATime”: “1”, “iheartradio_new”: “1”, “security”: “https/2.0”, “security_version”: “2.0”, “privacy_mode”: “0”, “user1”: “274:524”, “user2”: “1896:2097”, “DeviceName”: “Salon”, “GroupName”: “Salon” }
Do you think I can upgrade them.
Thank you.
yes, you could have a try.
please try use this API to update
hi zpl1025,
thank you, it’s ok!
great.
Hi
I Have a Fosi T10 with old firmware, mcu version 14.
It’s possible to have a new firmware?
{ “language”: “en_us”, “ssid”: “Fosi Audio T10_1D1E”, “hideSSID”: “1”, “SSIDStrategy”: “2”, “firmware”: “4.2.8715”, “build”: “release”, “project”: “Fosi_Audio_T10”, “priv_prj”: “Fosi_Audio_T10”, “project_build_name”: “a31slave_noasr”, “Release”: “20200915”, “branch”: “stable/wiimu-4.2”, “group”: “0”, “expired”: “0”, “internet”: “1”, “uuid”: “FF31F012DF31E054B1E9D145”, “MAC”: “00:22:6C:0F:1D:1E”, “STA_MAC”: “00:22:6C:0F:1D:20”, “CountryCode”: “CN”, “CountryRegion”: “1”, “date”: “2023:03:21”, “time”: “00:10:39”, “tz”: “1.000000”, “dst_enable”: “1”, “netstat”: “2”, “essid”: “6B656C53”, “apcli0”: “192.168.1.21”, “eth2”: “0.0.0.0”, “hardware”: “A31”, “VersionUpdate”: “0”, “NewVer”: “0”, “mcu_ver”: “14”, “mcu_ver_new”: “0”, “dsp_ver_new”: “0”, “ra0”: “10.10.10.254”, “temp_uuid”: “4D837F79898EA78A”, “cap1”: “0x85240”, “capability”: “0x808c0”, “languages”: “0x6”, “prompt_status”: “1”, “dsp_ver”: “0”, “streams_all”: “0x7ffffffe”, “streams”: “0x7ffffffe”, “region”: “unknown”, “external”: “0x0”, “preset_key”: “10”, “plm_support”: “0x6”, “spotify_active”: “0”, “lbc_support”: “0”, “WifiChannel”: “1”, “RSSI”: “-43”, “battery”: “0”, “battery_percent”: “0”, “securemode”: “0”, “iot_ver”: “1.0.0”, “upnp_version”: “1005”, “upnp_uuid”: “uuid:FF31F012-DF31-E054-B1E9-D145FF31F012”, “uart_pass_port”: “8899”, “communication_port”: “8819”, “web_firmware_update_hide”: “0”, “web_login_result”: “-1”, “ignore_talkstart”: “0”, “silenceOTATime”: “”, “ignore_silenceOTATime”: “1”, “new_tunein_preset_and_alarm”: “1”, “iheartradio_new”: “1”, “new_iheart_podcast”: “1”, “security”: “https/2.0”, “security_version”: “2.0”, “privacy_mode”: “0”, “user1”: “311:524”, “user2”: “1896:2097”, “DeviceName”: “testt10”, “GroupName”: “testt10” }
Many tanks
Hello! As I see, my mini v3 is with “Huan_SoundSystem”
I can not control EQ neither WEB, nor 4STREAM app.
How can I fix it?
Could you please add my device?
{ “language”: “en_us”, “ssid”: “FCAUDIO_B495”, “hideSSID”: “1”, “SSIDStrategy”: “2”, “firmware”: “4.2.8631”, “build”: “release”, “project”: “Huan_FC-WB05”, “priv_prj”: “Huan_FC-WB05”, “project_build_name”: “a31slave_noasr”, “Release”: “20200831”, “branch”: “stable/wiimu-4.2”, “group”: “0”, “expired”: “0”, “internet”: “1”, “uuid”: “FF31F01215DC73E0990EF3BC”, “MAC”: “00:22:6C:19:B4:95”, “STA_MAC”: “00:22:6C:19:B4:97”, “CountryCode”: “CN”, “CountryRegion”: “1”, “date”: “2023:03:27”, “time”: “12:27:42”, “tz”: “1.000000”, “dst_enable”: “1”, “netstat”: “2”, “essid”: “5A6967676F32353032333130”, “apcli0”: “192.168.178.177”, “eth2”: “0.0.0.0”, “hardware”: “A31”, “VersionUpdate”: “0”, “NewVer”: “0”, “mcu_ver”: “195”, “mcu_ver_new”: “0”, “dsp_ver_new”: “0”, “ra0”: “10.10.10.254”, “temp_uuid”: “3F8C902633738BE0”, “cap1”: “0x1200”, “capability”: “0x28482840”, “languages”: “0x6”, “dsp_ver”: “0”, “streams_all”: “0x7ffffffe”, “streams”: “0x7ffffffe”, “region”: “unknown”, “external”: “0x0”, “preset_key”: “10”, “plm_support”: “0x54”, “spotify_active”: “0”, “lbc_support”: “0”, “WifiChannel”: “6”, “RSSI”: “-71”, “battery”: “0”, “battery_percent”: “0”, “securemode”: “0”, “iot_ver”: “1.0.0”, “upnp_version”: “1005”, “upnp_uuid”: “uuid:FF31F012-15DC-73E0-990E-F3BCFF31F012”, “uart_pass_port”: “8899”, “communication_port”: “8819”, “web_firmware_update_hide”: “0”, “web_login_result”: “-1”, “ignore_talkstart”: “0”, “silenceOTATime”: “”, “ignore_silenceOTATime”: “1”, “new_tunein_preset_and_alarm”: “1”, “iheartradio_new”: “1”, “new_iheart_podcast”: “1”, “security”: “https/2.0”, “security_version”: “2.0”, “privacy_mode”: “0”, “user1”: “323:524”, “user2”: “1892:2097”, “DeviceName”: “FCAUDIO_B495”, “GroupName”: “FCAUDIO_B495” }
e… this is not our products, and the EQ feature is implemented on the base board. So, I can’t help on this.
Btw, you could order boards from us ![]()
Projects added, could give it a try.
@BNC @Michele_Marc
When i check the update the voice say firmware update found
with … getMvRemoteUpdateStatus the response is 50
with the mobile APP the update not appear.
Did you redirect the OTA server to ours?
yes, I done it before to check the firmware.
Thanks, that worked.
Would you mind also adding these.
{ “language”: “en_us”, “ssid”: “MD 43261_311A”, “hideSSID”: “1”, “SSIDStrategy”: “2”, “firmware”: “3.6.5014”, “build”: “release”, “project”: “CVTE_MD_43261”, “priv_prj”: “CVTE_MD_43261”, “Release”: “20171114”, “group”: “0”, “expired”: “0”, “internet”: “1”, “uuid”: “FF31F012588FB7727945893C”, “MAC”: “00:25:92:61:31:1A”, “STA_MAC”: “00:25:92:61:31:1C”, “date”: “2023:03:30”, “time”: “09:42:04”, “netstat”: “2”, “essid”: “5A6967676F32353032333130”, “apcli0”: “192.168.178.84”, “eth2”: “0.0.0.0”, “hardware”: “A31”, “VersionUpdate”: “0”, “NewVer”: “0”, “mcu_ver”: “81”, “mcu_ver_new”: “0”, “ra0”: “10.10.10.254”, “temp_uuid”: “DFE39B09CB7C2FDC”, “cap1”: “0x505208”, “capability”: “0x28680800”, “languages”: “0x6”, “dsp_ver”: “”, “streams_all”: “0xfffffffc”, “streams”: “0xfffffffc”, “region”: “unknown”, “external”: “0x0”, “preset_key”: “6”, “plm_support”: “0x0”, “spotify_active”: “0”, “WifiChannel”: “11”, “RSSI”: “-84”, “battery”: “0”, “battery_percent”: “0”, “securemode”: “0”, “upnp_version”: “1004”, “upnp_uuid”: “uuid:FF31F012-588F-B772-7945-893CFF31F012”, “uart_pass_port”: “8899”, “communication_port”: “8819”, “web_firmware_update_hide”: “0”, “privacy_mode”: “0”, “user1”: “323:524”, “user2”: “5959:6291”, “DeviceName”: “Media Room”, “GroupName”: “Media Room” }
{ “language”: “en_us”, “ssid”: “test”, “hideSSID”: “0”, “firmware”: “3.5.3328”, “build”: “release”, “project”: “MD_tegroup”, “priv_prj”: “MD_tegroup”, “Release”: “20160728”, “group”: “0”, “expired”: “0”, “internet”: “1”, “uuid”: “FF310015B95FAD5921170B36”, “MAC”: “00-22-6C-62-26-FC”, “date”: “2023:03:30”, “time”: “09:42:34”, “netstat”: “2”, “essid”: “5A6967676F32353032333130”, “apcli0”: “192.168.178.76”, “eth2”: “0.0.0.0”, “hardware”: “A31”, “VersionUpdate”: “0”, “NewVer”: “0”, “mcu_ver”: “0”, “disable_mcu”: “0”, “mcu_ver_new”: “0”, “ra0”: “10.10.10.254”, “temp_uuid”: “6AD7A1D5ECB625B9”, “cap1”: “0x400”, “capability”: “0x400”, “languages”: “0x6”, “streams_all”: “0x7ffffffe”, “streams”: “0x7ffffffe”, “region”: “unknown”, “external”: “0x0”, “preset_key”: “6”, “plm_support”: “0x0”, “WifiChannel”: “1”, “RSSI”: “-28”, “battery”: “0”, “battery_percent”: “0”, “securemode”: “1”, “auth”: “WPA2PSK”, “encry”: “AES”, “psk”: “Waitw0rd87”, “upnp_version”: “1001”, “uart_pass_port”: “8899”, “communication_port”: “8819”, “web_firmware_update_hide”: “0”, “user1”: “319:524”, “user2”: “5959:6291”, “DeviceName”: “test”, “GroupName”: “test” }
{“language”:“en_us”,“ssid”:“SBoommMR200_0560”,“hideSSID”:“0”,“firmware”:“3.5.3624”,“build”:“release”,“project”:“MD_SBoommMR200”,“priv_prj”:“MD_SBoommMR200”,“Release”:“20161024”,“group”:“0”,“expired”:“0”,“internet”:“1”,“uuid”:“FF310026E984C71AD6F4F1D3”,“MAC”:“00-22-6C-5D-05-60”,“date”:“1970:01:01”,“time”:“00:01:12”,“netstat”:“2”,“essid”:“5A6967676F32353032333130”,“apcli0”:“192.168.178.179”,“eth2”:“0.0.0.0”,“hardware”:“A31”,“VersionUpdate”:“0”,“NewVer”:“0”,“mcu_ver”:“0”,“disable_mcu”:“0”,“mcu_ver_new”:“0”,“ra0”:“10.10.10.254”,“temp_uuid”:“9084E5C53434CCE5”,“cap1”:“0x400”,“capability”:“0x400”,“languages”:“0x6”,“streams_all”:“0x7ffffffe”,“streams”:“0x7ffffffe”,“region”:“unknown”,“external”:“0x0”,“preset_key”:“6”,“plm_support”:“0x0”,“WifiChannel”:“11”,“RSSI”:"-78",“battery”:“0”,“battery_percent”:“0”,“securemode”:“1”,“auth”:“WPA2PSK”,“encry”:“AES”,“psk”:“Waitw0rd87”,“upnp_version”:“1003”,“uart_pass_port”:“8899”,“communication_port”:“8819”,“web_firmware_update_hide”:“0”,“DeviceName”:“SBoommMR200_0560”,“GroupName”:“SBoommMR200_0560”,“user1”:“323:524”,“user2”:“5959:6291”}
Hi
I downloaded the firmware from here
http://ota.rakoit.com/third/Fosi_Audio_T10/product.xml
and installed with the update tool.
Now I have the 4.6 version with the 14 MCU version
All works well but not the USB port for the usb stick, it’s not selectable anymore.
Many tanks for the firmware
wow, you’re export on MTK chipset. ![]()
You’re a so early user of Linkplay devices ![]()
I’ve added for this 3 devices, but upgrade on your own risk. I don’t know if it will work or not.
It worked fine for 1, but the other 2 now don’t play audio. Is there anything i can try to fix it?
You can download firmware from here https://silenceota.linkplay.com/wifi_audio_image/products.xml and i think for sure some will work,update with update toll for windows, maybe you cant find for your device on this site.
