This article summarizes the changes for the newest S50 Pro+ firmware release on April 28.2022.
What’s New:
- Improved OLED display
- Add preset EQ, Flat/Classic/Pop/Rock/Jazz/Vocal
- Adjusted default volume step to 5
- Adjusted minimum MXV to 30
- Add extra IR code for power on and power off
- Will reboot the device and enter WiFi mode when the sleep timer is out, to avoid the system not responding on standby.
- Show mute image instead of blinking 00 when muted
- Will keep the last power state when power is lost and resume
- Add BLE appendix for BLE device name to distinguish with classic Bluetooth
Sync VB settings when set in ACPWorkbench - Fixed, can’t switch to LINE-IN mode on boot
- Fixed, used treble value for bass on boot
- Fixed, SPDIF input voltage level
- Fixed, the OPTICAL input state is incorrect when switching source out and back
- Fixed, the SPDIF/I2S signal is not stopped when the system standby
- Fixed, system detected silence when the input level is low
- Fixed, some devices have a beep sound
April 30.2022 Update
- Support gapless playback
- Http API for playing notification(Smart Home)
httpapi.asp?command=playPromptUrl:[URL]
- Fixed, http API reboot not working
Web Player New Features:
- Some improvements in Personal Radio and Audio Settings
- Personal radio
- Audio settings
- Need password for the whole page
- Set title for page
4.6.415145.35(Updated)
- Fixed the bug that S50 Pro+ can’t power on after the update.
