We are figuring out the issue to check if this is software related or hardware related.
Here you are
Hello, I think I’ve bricked my B50 while upgrade its firmware.
I had .50 version, and successfully update it to .52 via flash drive.
After that I used your newest Update Tool, but in the middle of update my laptop disconnected somehow.
After that on B50 light was on DAC mode. It won’t respond and not controlled by app or remote.
I try to update again but app can’t find B50 anymore.
Now it won’t turn on. Remote doesn’t work, reset button also didn’t respond. Please help.
You try following these steps.
It still only have red stanby light on. No control via remote or knob with connected hdmi as you suggested .
Ok please let us know what you find
Any update? Looking at buying something else soon…
У меня стал более тусклым светодиод “OPT”
Hi, I can’t see my firmware version on my GoControl App. I’ve even tried to install the latest firmware following the procedure via USB, but nothing happened. No sign of LED blinking as well.
No new updates?
