Hello everyone! This is editor Joy!
Today I am going to share an interesting multiroom project to you. It is made by Martijn from Netherlands!
What is in Martijn mind"I have made two 6-zone multiroom amplifiers using 12 Up2Stream AMP V3’s.
They are mounted in a 19’’ inch rack with an internal ethernet switch and are powering in-ceiling speakers in 12 different rooms. It is working perfectly!
Thank you so much for your wonderful products, incredible value for money!"
Martijn here, creator of this build
The power supply is a Meanwell SNT HRP 600 24 (24V 650W). It delivers just under 110W per board (I have 6 boards per amp).
So far the amps are working beautifully! They have plenty of power and sound nice
I have one annoyance though which I hope you guys at Arylic can fix with a future firmware update:
I’m using these amps in a permanent in-ceiling speaker installation. Some rooms have more than one pair of speakers, so I use the multiroom grouping feature to link the speaker pairs in the same room together as one.
This works great, however after each automatic firmware update or after a power cycle the groups I’ve created are lost and all amps are set individual again. So after each firmware update I have to re-group the speakers everytime. This is very annoying.
Can you provide a future firmware update, so that the user created groups are saved and also remain after updates and power cycles/reboots?
That is an awesome build. I’ve built something similar (to be posted soon) but your build gave me lots of good ideas to add and reminded me that I need to prioritize my cable management. Thanks for sharing.
Hi @Martijn, it is supposed to save the multi room configuration after power off and on, currently firmware seems have some problem in this, we’ll look into it and find a solution.
