so, does someone have some news about this problem ?
R.B.
someone who suffer from this issue want to help testing? Iāve pushed a version for UP2STREAM_AMP_V4 to the alpha server, and you could upgrade with API: http://DEVICE_IP/httpapi.asp?command=SetUpdateServer:http://ota.rakoit.com/alpha remember to replace the DEVICE_IP with real IP of device. And then would show new version on APP.
Can I test it for the Up2Stream Amp Mono too?
OK, this update seems to work for me⦠letās wait a few days to see if the issue is not coming back again.
The APP still asking for a new version even after upgrading⦠is that normal ?
it works!
when will be the official version is rolled out?
seems to work fine, thanks!
Does this work with the Up2Stream Mini too?
Hello there ![]()
After a long break and big troubles with bugs and disfunctions Iām back.
Unfortunately I have to see, that the Arylic software is still broken. ![]()
Already tried the alpha firmware on my mini v3 boards. The volume is still 0% or 100% in group mode for the group master.
At least the group slaves volume works ok, untill I set the volume slider of master unit to 0% = every group remains dead silent.
