So, i’m a little bit stuck. I found a non solution. I exchange de wiring and put the color to the 3v3 and the anode to a color and it’s working but… only for one color… So the rgb led is a kind of un useful…
@Tot sorry for the late reply. If you have a voltage tester I would start with changing the colour of the main LED and measure the pins on the board for correct voltage.
