Up2Stream Plate Amp 2.1 portable sound system with Dayton Audio Epique subwoofer and passive radiators
My first project using the great plate amp
Love the plate amp - makes it easy to get a clean and professional setup.
My first project sounds great, but the passive radiators I used hev problem to handle high volume.
Decided to start a new build (v2) where I replace the subfoofer and radiators with the 7" Dayton Audio Epique + 2 x Epique passive radiators (hope this is a ok combination)
I`ll keep the DD audio 5.25" speakers to handle mid/high frequencies.
And the great plate amp…
Have started working on the updated design - I`ll share images later
Playing with the v2 design (only one speaker at the moment)
I`m going to use the same speaker positions as in V1
The idea is something like walnut on top/bottom and balck leather on the front/sides…
Something like this (not the correct speaker elements in the 3D model)
The led ring is a combined push button/RGB LED used for mode selection (Bluetooth, WiFi…) each mode have a different color (I`ll share more information about it later)
The Up2Stream Plate Amp 2.1 at the rear.
This amp is perfect for projects like this - a lot cleaner/more professional setup compared to my first build where I used the standard 2.1 module.
The old passive radiator used in v1 vs the new one for v2
Exiting
First test installed in V1 (not tuned…)
Have to find some better test music
Awesome!
Hope your neighbors enjoy :sunglasses:. Don’t forget to provide some details on the LED ring you mentioned.
In my V1 project I used a RGB led ring push button - different colors = different modes (bluetooth, usb…)
But in V2 I plan to use a NeoPixel led ring push button in combination with a arduino to get more colors/more options… (winter project)
I promised to share how I connected the RGB mode select push button in V1
Made a simple wireing diagram
Made a short demo video
Solid Green = WiFi connected
Blinking BLUE = Bluetooth not connected
If I connect using USB, I get solid Red
Used the connector at the mid top (same as on the standard Amp 2.1
You can add other buttons for Vol +/- … by including more push button/resistor combinations.
For V2 I plan to test a setup where I use a neopixel based bush button in combination wit an Arduino to cover all modes…
It is also possible to include a small OLED display that can display the mode using text
In V2 I`ll include control buttons (previous, next, pause/play and vol up/down)
I`m going to use an PS-BC12113 BCPB4 Battery Manager Module 5x26650 for my V2 build
Some parts for my new neopixel led ring button for mode select/status arrived today - soon I’ll have all the parts I need to test my idea :blush:
315502669_865909134759211_5302495561886229996_n
I`m going to order some walnut wood for my V2 build
Love the look
First test - Neopixel led ring mode select button
In this test I use 4 buttons to simulate 4 modes (bluetooth, Wi-Fi …)
The colors are only for test - I can use other colors)
Congratulations! Your Post Win our 4th Anniversary Giveaway Contest.
We already sent a mail to you for the instructions to get the prize.
Please check your mail:)
Some design updates - while waiting for the Walnut wood…
Plan to install braces like this
Not decided if I should make a dedicated chamber for the Arylic Plate Amp + battery module
The prize from the contest arrived today, together with an extra surprise :smiling_face_with_three_hearts:
Hello I love the boom box. It looks great. I also have the Dayton LBB – 5V2 battery pack that I’m trying to hook up to the up2stresm 2.1 plate amp. How do you hook those two together? Thanks, Kerry
Hello.
I have recently received my Up2Stream 2.1 plate amplifier and plan to use a led illuminated push button like you in my project. I can’t find a cable connector that fits. What is that type, and where can it be bought?
// Per
Sweden
I just purchased some on eBay, search for Small 8mm 10mm Metal Push Button Switch 4pin LED Latching Momentary
Steve
