Is it possible to connect a USB key with .wav tracks and listen those files ?
Paul,
Will check tomorrow.
However beware of the USB route for plentiful audio files. The number of tracks loaded in UI is 124. Arylic Audio HTTP API
Regards, Kevin
Thanks Kevin,
I connected a USB key with .wav files. But how to see the files and how to start playing from APS???
Thanks
BROWSE >> MY MUSIC >> USB DISK should appear
Founded! Thanks
Do you thing the limitation to 124 files will be upgraded ? My playlist is more than 4000 files. ?
Thanks!
Paul,
I think you will find your answer and some work arounds in this post.
btw @zpl1025 Frank Zhang is technical person from Arylic.
Hope this helps,
Kevin
