New Upgrade Tool For Our Bluetooth Products
:disguised_face:We know that upgrading your product with a USB drive could be a bit tricky for some. We’ve listened to your feedback and are excited to introduce a new, simpler way to upgrade. With our latest tool, you can now easily update your device directly from your windows laptop or PC.
“The Arylic Update Tool is now available for B50、BP50”
:pushpin: Before starting, you need…
  1. Prepare a Windows computer(Win 10 above, includes Win10)
  2. Prepare corresponding power adapter
  3. USB A to USB C data cable
*USB-C to USB-C cables are available, but for firmware version .52 or lower, use a USB-A to USB-C cable.
Step 1: Download the Update Tool
Click here to download the update tool, and uncompress the folder.
Step 2: Connect Your Devices
Check if you computer audio output option pops up with “Up2Stream USB Audio”
If yes, the device is connected successfully.
If not, please confirm your USB cable is data transmit avaiable, and use USB A to USB C data cable and try again.
Step 3: Run Arylic Update Tool
Open the Arylic Update Tool folder your just uncompressed, and click the .exe file to run the program:
You will see the program recognize your model and your current version, choose the firmware version you are going to update and click update:
Ensure your PC/laptop is connected to the network. The update tool will automatically fetch the latest firmware list via network.
*The local update is for special scenario to update with the local firmware file.
Wait about 30 Secs to finish the update
:pushpin:Very Important
  1. Do not power off or disconnect the USB cable during the update.
  2. Do not close the program during the update.
When finished, the device will reboot automatically. You will see the Led turn to standby and turn back.
When the Led turn back, everything is done, you can start to use now.
You can check the current version with this update tool or in GO CONTROL APP to see if the update is successful.
:pushpin: Note
  1. This is Windows software ONLY(support Win 10 above, includes Win10)
  2. Make sure your USB cable is data transmit available, not a charging cable
  3. Better use USB A cable to USB C cable.
  4. The Arylic Update Tool is now available for B50、BP50
  5. Do not power off or disconnect the USB cable during the update.
  6. Do not close the program during the update.
:warning: If the upgrading is failed for any reason, please don’t cut power or disconnect USB, but just try to upgrade again.
You can find the firmware updated content with our previous post:
B50 /BP50 Firmware Version Update 0057-5be7aedf
If you encounter any issues when updating, feel free to contact us at info@arylic.com
Or leave comments below if you have any suggestions! :grinning::grinning:
Find the Product mentioned in the post:
:point_right:B50 Bluetooth Stereo Amplifier
:point_right:BP50 Bluetooth Stereo Preamplifier
Hello, I think I’ve bricked my B50 while upgrade its firmware.
I had .50 version, and successfully update it to .52 via flash drive.
After that I used your newest Update Tool, but in the middle of update my laptop disconnected somehow.
After that on B50 light was on DAC mode. It won’t respond and not controlled by app or remote.
I try to update again but app can’t find B50 anymore.
Now it won’t turn on. Remote doesn’t work, reset button also didn’t respond. Please help.
Hi Mumax, I saw we already talked on the mail.
Will help you solve the issue there.
Yes, thanks! Will wait to email from AliExpress colleague.
What do You mean by “… disconnected somehow…” .
Did it happen due to an external event or by the software tool itself ?
I would be reluctant to use it, if it happened by a “bug” within the software…
none of the updates work. I just downloaded the latest one and all the lights come on for a while when I change the source and bt no sound at all
Bp50
For those who could not update using Arylic Update and DAC interface. My situation was that I could see updates for BP50 both 56 and 57. I could click on Update button in “Arylic update” window. But the only thing that happened was that it downloaded the zip file ARYLIC_BP50-0057-d94126e9-20240918.zip and that’s it. Update button was grey and nothing else happened. I had to unpack the zip file and use “Local Update” select the ARYLIC_BP50-0057-d94126e9-20240918.MVA and hit Update. Green bar showed up and in 30secs “Update successful” has shown up.
Cheers!
Does the current Firmware installed by this tool fix the random line-out cut-out that requires user to turn the device on and off to restore power?
I’m pretty hesitant to try and update unless I know that it will fix the biggest problem that the BP50 has…
I tried this but when the update was complete the tool just shut off and my b50 has no firmware now. What should i do ?
I’ve bricked my BP50 with the update tool.
I started to install the 57 firmware and after running for while it said sth. like “Something went wrong. Please try again.”
Now the device is not recognized anymore and only lights up “STBY” in red.
Any ideas to get it working again?
Please help me, I update to 57 standby lights on continuously. Cannot change modes. Rotten app! Resolve this issue immediately
I would like to know, if anyone in support is paying attention to these threads on the B50/BP50 firmware update issues. We bought your products, followed your update instructions, and now we have a device that is unusable. Could someone from give us some acknowledgement that you understand our need and are working to solve the problems?
What can I do with this pin on the motherboard? send me an application to be able to flash via this pin.
Have you actually contacted support? The Forum is read by users more than the support staff
@joia @zpl1025 @Joy
If this problem has not been resolved, I suggest that this forum be closed. Because I as a consumer feel disadvantaged by the information provided. Please be responsible, my machine is on continuous standby and cannot be used.
@Joy
Hello,
I had the problem, that my B50 start every time with bluetooth and I had to change to ARC.
The Support send me the link to this chat in the forum.
I update my B50 and everything worked. I had now problem to update the firmware. B50 start now in the last choosen option (ARC).
The update tool is "Arylic Update V1.1.1
and the new Firmware for my B50 57-5be7aedf
I’m really apprehensive about updating the firmware. Isn’t there any way to correct a mistake during the process? I don’t want to end up throwing away the device over something so trivial.
Just received a B50 and trying to work out what the most recent firmware is, can anyone confirm ?
I’ve tried downloading the tool , but the program just opens and closes before I can do anything.
Any help would be good as I have issues with thr B50.
Thanks
