Using the IR remote, I am unable to adjust the volume of a device in a group.
IR to Master
- Play / Pause / Next / Prev
- Volume Control (+/-)
- Mute
IR to Slave
- Mute
IR to Master
IR to Slave
@mclarkdev Matt,
You are definitely opening a can of worms here
Rhetorical Question coming. How should it work ? I am not sure
Never tried doing anything like that but I do have questions about your Slave Tests.
Regards, Kevin
I am working to build the ultimate smart home experience
; IR control to the slave, has indication beeps however no volume adjustment is made to any device, i would expect IR to slave to adjust volume of slave
I definitely have a knack for finding small bugs, but I am absolutely loving playing with this system so far! Donโt let these posts say otherwise <3
Matt,
I need to get my head around the multiroom thing for this project:
I need to go back through the command sets (HTTPAPI, TCP/IP, UART, DLNA/UPNP) and it seems BLE is a new one too
and with the help of Arylic figure out all the Master <> Slave Stuff. Itโs definitely on other side (The MCU with a TCP/IP Service) but how it is presented to the various command sets needs some work to figure out. Also worth checking out Linkplay https://www.linkplay.com/modules-wi-fi-2. The A31 is the board used for a lot of the Arylic Products.
The Linkplay detailed documentation is poor (itโs more of an OEM thing IMHO). Arylic are very open, progressive & customer orientated. However there are limitations of what they can do with the A31 module - some functionality and peculiarities will always be dictated to some extent by Linkplay.
So I think the multiroom Master <> Slave Stuff was/is/could be a Linkplay thing. Just wanted to warn you if you werenโt aware.
Enjoy playing, the devices sound great for the money and offer plenty of functionality to boot
Keep going with the observations, questions etc. etc. ![]()
Kind Regards, Kevin
