After upgrade to the latest firmware (the device upgraded itself) the bass level is much lower now on my mini v2 device. I’m using analog output.
Maybe VBS was enabled in previous firmware so I want to enable it. I don’t have ACPWorkbench to check settings so I want to use uart passtrough.
But my device doesn’t respond to those commands:
MCU+PAS+RAKOIT:VBS&
MCU+PAS+RAKOIT:VBS:1& enable VBS
MCU+PAS+RAKOIT:VBS:0& disable VBS
uart passtrough works as command MCU+PAS+EQGet& returns
MCU+PAS+EQ:treble:8&MCU+PAS+EQ:bass:9&
This is my hardware:
{ “uuid”: “FF31F09XXXXXXXXXXXXXXXCB”, “DeviceName”: “Yamaha”, “GroupName”: “Yamaha”, “ssid”: “SoundSystem_6CC5”, “language”: “en_us”, “firmware”: “4.6.329454”, “hardware”: “A31”, “build”: “release”, “project”: “RP0013_WA31S”, “priv_prj”: “RP0013_WA31S”, “project_build_name”: “a31rakoit”, “Release”: “20210915”, “temp_uuid”: “A98FB52C21C179A1”, “hideSSID”: “0”, “SSIDStrategy”: “2”, “branch”: “A31_stable_4.6”, “group”: “0”, “wmrm_version”: “4.2”, “internet”: “1”, “MAC”: “00:22:6C:10:6C:C5”, “STA_MAC”: “00:22:6C:10:6C:C7”, “CountryCode”: “CN”, “CountryRegion”: “1”, “netstat”: “2”, “essid”: “7265642D70696C6C2E6575”, “apcli0”: “192.168.133.31”, “eth2”: “”, “ra0”: “10.10.10.254”, “eth_dhcp”: “1”, “VersionUpdate”: “0”, “NewVer”: “0”, “set_dns_enable”: “1”, “mcu_ver”: “6”, “mcu_ver_new”: “0”, “dsp_ver”: “”, “dsp_ver_new”: “0”, “date”: “2021:10:17”, “time”: “06:46:16”, “tz”: “1.0000”, “dst_enable”: “1”, “region”: “unknown”, “prompt_status”: “1”, “iot_ver”: “1.0.0”, “upnp_version”: “1005”, “cap1”: “0x305200”, “capability”: “0x28690b80”, “languages”: “0x6”, “streams_all”: “0x7ffffbfe”, “streams”: “0x7f9831fe”, “external”: “0x0”, “plm_support”: “0x0”, “preset_key”: “10”, “spotify_active”: “0”, “lbc_support”: “0”, “privacy_mode”: “0”, “WifiChannel”: “13”, “RSSI”: “-64”, “BSSID”: “50:D4:F7:FA:25:FB”, “battery”: “0”, “battery_percent”: “0”, “securemode”: “0”, “auth”: “OPEN”, “encry”: “NONE”, “ali_pid”: “RAKOIT_MA1”, “ali_uuid”: “”, “upnp_uuid”: “uuid:FF31F09E-EC1A-E7EA-ADA0-F9CBFF31F09E”, “uart_pass_port”: “8899”, “communication_port”: “8819”, “web_firmware_update_hide”: “0”, “ignore_talkstart”: “0”, “web_login_result”: “-1”, “silenceOTATime”: “”, “ignore_silenceOTATime”: “1”, “new_tunein_preset_and_alarm”: “1”, “iheartradio_new”: “1”, “new_iheart_podcast”: “1”, “tidal_version”: “2.0”, “service_version”: “1.0”, “security”: “https/2.0”, “security_version”: “2.0” }
Any idea how to enable VBS?
