Thanks for the answer
unfortunately that doesn’t work for me.
the website hangs like frozen.
It would also be much better to be able to control this in the app.
Do a factory reset on the device with the 4Stream app. You will need to setup the wifi again. You may also need to delete browser cache. I had to factory reset one of my devices 2 times before the page worked correctly.
I am unable to use the new EQ settings. It isn’t clickable. Any help would be greatly appreciated.
Hi, since upgrading to this firmware I notice that after a while connected to wifi, the green Line in LED also lights. Audi doesn’t appear to be affected. I’ve seen this on 2 different up2stream2.1 boards now. What does it means and is it a problem?
Hi
After the last OTA Update, all my mini V3 boards suddenly start randomly to enter setup mode with the voice output Looping every 20 sec. After power cycle they reconnect again and work just fine but they are installed in my kids’ bedrooms and in the middle of the night start randomly talking.
Never had any issue for a few years now and suddenly after 27th April they all started this behaviour.
Did several factory resets on all of them with new setup. Then works for half a day until it all starts over again.
Any ideas?
Hi Phillip, That’s strange. How’s the connection for the boards? Did you use the ADCKEY? And is there any chance that the board might receive a IR command?
Hi
They are simply powered by a USB Charger and drive a pair of cheap PC-Speakers via 3,5mm jack. IR command would be very unlikely since I have 4 boards in different rooms all showing the same behaviour.
As mentioned, did not have any issue since I installed them like 2 or 3 years ago and since they updated on april 27 they all showed this. so it looks very likely to be some hickup with the firmware.
Another fun fact: they always seem to start within one or two minutes in the morning at 06:00 hrs am and pm. As far as I could reproduce it.
What the heck?
No,I checked the log too, not even dsl-reconnect at that time.
Other devices were connected then.
And as I said, nothing in my system changed, it all worked well and from the day of the update it all started.
Is there any way to roll back to previous version to test?
Ok we so far solved it. My router did some band steering and changed the wifi chanel from time to time. This disconnected the boards which aometimes triggered the setup mode. Although this is unwanted and will be fixed, turning of the band steering for the 2,4GHz wifi solved it for now.
