Firmware Upgrade 4.6.337862
New Features:
  1. Web Player:
    -Music Player
    -Switch Audio Source
    -Play Radio URL
    -Play Preset Content
    -Web Management(Firmware Update, Connect to AP, Factory Reset)
How to use the web player?
  1. Enter you device ip to your browser
  2. Enter the password “admin”
  • The device need to under the same network with your PC.
Want more features? comments below share your ideas!
We will add more new features soon :wink:
Improvements:
  1. Improve iTunes streaming more stable and fast
  2. Under the WiFi or nerwork mode, open hotspot in 4stream App and restart will see the device SSID.
  3. Under multiroom mode, multi-room input source volume (Spotify), master and slave volume consistent.
Bug Fixed:
  1. Fixed WiFi paring issue that WiFi can’t be paired sometimes.
  2. Fixed Airplay playback cut off and disconnection.
-12.08.2021
@joy looks good :slight_smile:
Looking forward to using it :+1:
Sure:) not much features currently, but plan to develop as a very useful tool for customers :grin:
And so fast for your reply :+1:
Thanks for update, I would really like to improve remote control volume up and down,there a delay when i press and hold Volume up or down ,also anoying beeping sound for every command when i use remote especially when i press and hold volume up or down, beeping is louder than music… :+1:
Hi Viktor, thanks for the quick reply.
You can solve the beep sound by this way:
Here is the steps:
  1. Download the tool.
2.input you device IP then click connect(you can find device IP settings> speaker info> device IP)
3.input the commend MCU+PAS+RAKOIT:BEP:0& then click send.
And I think your issue will be solved. :slightly_smiling_face:
Finally :grin:,Thanks a lot,i made it,:+1::pray:
The web interface looks nice, thanks for this feature!
Now I’m wondering what to do with it in a corporate multiuser environment …
Is there a way to restrict user access to playback control? (username+password)
Or disable playback web interface completely in settings?
no… currently the web app only controlled the settings with password but not the playback, I think it’s not a issue since user in the same network can always control it with app.
It’s kind of a possible misuse vulnerability issue in my case. When anyone who gets to device via IP has playback control.
I have some PCs in local network, can’t isolate them. As for wi-fi devices with app - it’s much easier to isolate them in a guest network.
  • there’s a risk of intrusion after all.
    Imagine if someone gets remote access to you network and starts messing with your sound system (((
    Sonos went another way here – they have user accounts in their mobile and desktop app.
understood, will consider it
Would be great if anywhere in the window would be the name of the player (device name) I have 10 boards in my network. So would be great to know which device I’m control now
Please have an update for Tidal Endpoint
@Geo George,
Depending what Router Make & Model you have it might be possible to restrict access to the Web Server Interface to one or more MAC Addresses (or IP Addresses assuming Fixed IP).
If you post you’re Router Make & Model I will have a look at the Manual to see what’s possible.
Regards
Kevin
Great, finally a pc software independent playback option (the foobar is a horror)!
A few questions:
  • where can I find the file browse mode (which allows me to load a music file directly into the player),
  • how can I edit and save the preset list, and
  • how can I save the radio urls permanently?
Thanks for the new firmware. The functionality of the products are still growing which is great . One thing i’m still missing is the update of the song while listening to a tunein station. When you start a tunein station the song and title are shown of the song playing when you start the station but is never updated.
Thank you, Kevin. I have a Keenetic ULTRA (KN-1810) router there.
First idea that came into my mind in this situation was putting all amps in a separate network subnet segment with restricted access…
A option to “pass” the music to another room. Or make another speaker of a group the new “master” would be handy.
Will web based app (4.6.337862) work in harmony with existing 4stream App (ios)?
Hello
I followed the directions above but only see the elapsed time in the browser window
No album art ?
Did I make a mistake?
Thank you
Thank you very much for developing this very useful feature. If multi room options and the ability to see the flash memory content connected to each device are added, it will be much more useful.
