Hi All,
I will be REALLY happy if I can get this funcitonality working.
I understand it only works via network or usb playback mode, and only in firmware 4.6.415145 and later; I am working within those constraints.
I tried it too. Feedback is “OK”, but no sound. If I spell the link wrong, feedback is “FAILURE”. If I type it correct, feedback is “OK”, but no sound.
Hi, did you solve the issue? I did not see any abnormal in your API requests, it should work. And I also tried it on my device, it works fine with browser/python/curl.
And btw, another point, this API does not support to play https links, it will say OK, but won’t play it.
And I’ve also tried a not existing command, it will reply unknown command
I’ve tried to play a not existing file, it will reply Failed, this should be your case.
Maybe could try to play the link directly with this API, and see if it works. command=setPlayerCmd:play:
Wow! I really appreciate you checking in! I’ve been at a standstill with this since the time of my post. I’ve screwed around with it a little more, but no dice. I have a very kludgy workaround, but I prefer not to use it.
If I may ask, does your implementation work with pretty much any .wav or.MP3 file you throw at it?
I’m super excited I figure it out is shell script for an apple script to translate text commands into system speech, then save them as an audio file. Also, I would like a doorbell again. Any pointers or tips very much appreciated!
This is important intel for me! I’m 100% certain I tested it with MP3 files that I could otherwise play in VLC player or whatever, but that constraint is a good one to know. I kind of assumed it would play uncompressed better than compressed, but I am far from an audio software engineer, so what do I know
I will try it again, maybe it was entirely user error
