I have a BP50 and it works really well in my use case. I use Line input probably 90% of the time to feed my TV to my power amp and speakers. The TV optical out connector is messed up so I use the RCA outs. I have had BP50 for about 2 months, about a month in use the Line indicator stopped lighting up. All other input modes still show up but not Line.
Occasional I use BT mode to listen to audio from my iPhone, but not that often.
I have also had the same issue. My DAC input LED started going out about a month after I first purchased my BP50 in September '23. Arylic replaced my unit in October, but now my DAC input indicator has almost completely burned out, and the OPT and LINE indicators are also visibly dimmer than the other less used inputs. I’m going to reach out to them again about replacement, but seeing as this likely wasn’t a one-off I’m regretting my choice to purchase the BP50.
You only need a size 0805 led. I got it in an online shop. Various colors you can choose. Because the Bluetooth indicator is problematic, I prefer to replace the default white LED with blue.
At least you understand how to use a heating tool to remove a damaged LED. It requires patience and precision, because the size of the 0805 LED is very small.
