First of all, very appreciate our customers always positively give us helpful feedback to improve our products.
Recently, we are ready to release an enormous change of App and firmware update which may improve the usage experience a lot. Especially the multiroom control and network connection.
Before that, we want to invite our forum members to test the beta firmware and 4stream APP to help us make the new upgrade more better.
Very appreciate for your help and feel free to comments below to let us know your idea or any issues you meet! OK, Let’s go!
I have successfully installed on two devices. Not tested yet.
When I downloaded the windows tool I had this filename:-
You see that there are Chinese characters and windows will not recognise the file as an application. However if I remove the characters manually (rename the file extension) using file explorer I get this
Now I can execute the tool as I now have a .exe file which windows recognises as an application.
Secondly could someone explain the “Improved Network Status Recognition” ? The Improvement is not obvious to me so far.
Beta Firmware is working great, some minor improvements might be needed : (from Pro V3)
-It seems like wifi hotspot is restarting at every boot (stays on when the board is fully connected to my wifi). the name of the hotspot is the original one (soundsystem_xxxx).
-EQ is loosing track and resetting
Wifi connection seems to be working a bit faster
App : (android)
-EQ doesn’t display properly (and a 3 bands EQ could be a realy good improvement)
-New audio switcher not implemented yet (i think it is normal)
Just downloaded new iOS app to look it over. Like that things have been cleaned up a bit. New source selection interface is clean and simple. Simplified speaker group pairing is nice. Way better than drag and drop. Wondering where the eq settings are? Can’t find it in iOS app and minor eq adjustment from the app has been very useful for me. I would actually like to see an expanded eq ability from the app outside of using acp workbench. I use acp workbench for crossover settings on my builds and flatten and smooth any problem areas in frequency response. Having eq available on the app for the end user to slightly warm or brighten overall sound is very important for end user satisfaction. Keep up the great work.
Hello,
I updated all 11 of my units with the latest beta firmware today and now I’m getting a lot of skipping in my Pandora music. All the units worked great before. Where can I get the old copy of the firmware to go back to and try and correct the problem? Thanks Steve
So, will you update the HTTP API documentation, too? In general I would highly appreciate it when if this documentation always represents the current status of all available features provided by the LinkPlay boards.
Hi to everyone, I don’t know is it a good place here to ask but i need some information about linkplay a31 modul that are in v3 amplifier,my upnp server is native upnp server from kodi (libreelec,openelec) never menage to play songs from kodi mediacenter upnp server,i will come to every folder and songs, but after enter play song just skips all the songs to the end of folder,did any of member here use kodi server and have this experience? I stream with yamaha wxc 50 without problem and with another platform but no luck with linkplay,i have also two different linkplay device and i have same problem,i try new beta app and firmware but problem exist,Thanks. Viktor
I installed the app 4STREAM beta and the firmware update v4.6 hoping that the new Spotify SDK would now enable Spotify Connect. Unfortunately this is not the case and Airplay (or Bluetooth) is the only option although in the device list SoundSystem pops up (greyed out) but is not selectable. Can an update offer this possibility in the future?
