Antenna - ufl connector type - confused
Hi guys,
after a year on playing with my speaker i have discovered i need an upgrade for my wifi antenna.
The UFL IPEX coonector comes in various sizes.
From this site:
Can anyone enlighten me.
Many thanks in advance
Kervs
After doing a day of digging here is what i learnt and hope it helps other Arylic lovers and tinkerers.
IPEX is product name by a 3rd party manufacture (the original connector developer U.FL) they are the same.
  • MHF1 - used for 2.4GHz devices (height 2.5mm)
  • MHF4 - used for 5GHz devices (height 1.8mm)
Arylic amps (as i know it) uses 2.4GHz so get yourself a IPEX - MHF1 connector
As for the other end - SMA or RP-SMA
it does not matter which choice you make - all the matters is the physical antenna connection type. IF you have a spare antenna laying around the house and intend to use it, buy the appropriate connector type.
If anyone can confirm my research i would really appreciate it.
Hope it helps !
Hallo
See: What type is the antenna connector of the WiFi antenna?
Greeting
