mzmn
August 11, 2021, 3:57pm
1
My new ISP appears to have some settings set in the provider router that is preventing my A50 from accessing the internet. It does have access to the wifi network though.
On my Samsung TV, I had to set the DNS to 8.8.8.8 and 8.8.4.4 (Google DNS) to get internet access. So, I want to try to do the same for my A50.
How do we change the DNS settings of our A50?
@mzmn @zpl1025
Don’t think there is a way right now. The proposed web interface should fix this
I suddenly have problem on one of my upstream mini V3, the IP always change everyday even i set max for dhcp lease time. I wonder there an option to set static IP. Thanks
Regards Kevin
mzmn
August 12, 2021, 12:22am
3
Thanks! Hope it comes out soon. Will test if a LAN cable can avoid any restrictions that may be active in WiFi network.
it currently does not support to change DNS in the web management page yet, I’ll check if can add a quick change before release.
@zpl1025 is it possible with httpapi Interface or ACP Workbench ?
no, the network related settings all inside the A31 module, the normal way is the httpapi, or the web page inside.
mzmn
August 18, 2021, 3:33pm
7
Was able to get the ISP to change to settings from a private network (10.x.x.x) to an accessible 192.x.x.x address.
So now it works.
