These power adapters are huge! Has anyone done POE with the A50+ yet? Anyone have an Amazon link? Thanks
Hi Phil,
If the power adapter “is huge” then there is a good chance that it would be supplying a fair amount of current to the device (check the label)
I think that POE can only supply up to about 100w max? Which is about 4 amps @ 24v. You would need to allow for voltage drop thru the ethernet cable also.
Ok thanks makes sense, figured as much
