I needed to synch the firmware for my Plate Amp and Sub in order to link them. The Plate Amp did not automatically update. I finally got the unit Firmware updated . I had to reset a few times before I was able to connect via web interface, but it eventually worked. I tried the same thing (Reset) with my Sub amp to get the web interface to work and had to use the alternate wireless method to reconnect. I eventually got that to work too. Then I was finally able to synch the Plate Amp with the Sub but the process was very frustrating.
The Firmware release I used was http://192.168.86.105//httpapi.asp?command=SetUpdateServer:http://ota.rakoit.com/alpha but it seems the release build was loaded.
Now though, the Volume control on the back of my Plate Amp doesn’t work. Not sure it worked before the F/W update as I never tested it. It does work normally on the Sub. Both my units are now on the same Firmware release.
Is there a fix to actIvate the vol knob control? FWIW I have ACP Workbench. Here is the information:
PLATE AMP
{ “uuid”: “FF31F09E25A25BF849A25422”, “DeviceName”: “ONS Speakers”, “GroupName”: “ONS Speakers”, “ssid”: “SoundSystem_8E1D”, “language”: “en_us”, “firmware”: “4.6.415145”, “hardware”: “A31”, “build”: “release”, “project”: “ARYLIC_V20”, “priv_prj”: “ARYLIC_V20”, “project_build_name”: “a31rakoit”, “Release”: “20220427”, “temp_uuid”: “4EFC39CCB65368DC”, “hideSSID”: “1”, “SSIDStrategy”: “2”, “branch”: “A31_stable_4.6”, “group”: “0”, “wmrm_version”: “4.2”, “internet”: “1”, “MAC”: “00:22:6C:38:8E:1D”, “STA_MAC”: “00:22:6C:38:8E:1F”, “CountryCode”: “CN”, “CountryRegion”: “1”, “netstat”: “2”, “essid”: “436F687273”, “apcli0”: “192.168.86.105”, “eth2”: “”, “ra0”: “10.10.10.254”, “eth_dhcp”: “1”, “VersionUpdate”: “0”, “NewVer”: “0”, “set_dns_enable”: “1”, “mcu_ver”: “35”, “mcu_ver_new”: “0”, “dsp_ver”: “0”, “dsp_ver_new”: “0”, “date”: “2024:02:23”, “time”: “16:15:03”, “tz”: “-5.0000”, “dst_enable”: “1”, “region”: “unknown”, “prompt_status”: “1”, “iot_ver”: “1.0.0”, “upnp_version”: “1005”, “cap1”: “0x305200”, “capability”: “0x28e90b80”, “languages”: “0x6”, “streams_all”: “0x7bff7ffe”, “streams”: “0x7b9831fe”, “external”: “0x0”, “plm_support”: “0x8006”, “preset_key”: “10”, “spotify_active”: “0”, “lbc_support”: “0”, “privacy_mode”: “0”, “WifiChannel”: “1”, “RSSI”: “-58”, “BSSID”: “F0:72:EA:85:1E:CA”, “battery”: “0”, “battery_percent”: “0”, “securemode”: “1”, “auth”: “WPAPSKWPA2PSK”, “encry”: “AES”, “upnp_uuid”: “uuid:FF31F09E-25A2-5BF8-49A2-5422FF31F09E”, “uart_pass_port”: “8899”, “communication_port”: “8819”, “web_firmware_update_hide”: “0”, “ignore_talkstart”: “0”, “web_login_result”: “1”, “silenceOTATime”: “”, “ignore_silenceOTATime”: “1”, “new_tunein_preset_and_alarm”: “1”, “iheartradio_new”: “1”, “new_iheart_podcast”: “1”, “tidal_version”: “2.0”, “service_version”: “1.0”, “ETH_MAC”: “00:00:00:00:00:00”, “security”: “https/2.0”, “security_version”: “2.0” }
SUBWOOFER
{ “uuid”: “FF31F09E47665A9816C56C70”, “DeviceName”: “Subwoofer”, “GroupName”: “Subwoofer”, “ssid”: “SoundSystem_22BD”, “language”: “en_us”, “firmware”: “4.6.415145”, “hardware”: “A31”, “build”: “release”, “project”: “ARYLIC_SUBWOOFER”, “priv_prj”: “ARYLIC_SUBWOOFER”, “project_build_name”: “a31rakoit”, “Release”: “20220427”, “temp_uuid”: “DBBB6613FCC2FC32”, “hideSSID”: “1”, “SSIDStrategy”: “2”, “branch”: “A31_stable_4.6”, “group”: “1”, “master_uuid”: “FF31F09E25A25BF849A25422”, “slave_mask”: “0”, “wmrm_version”: “4.2”, “internet”: “1”, “MAC”: “00:22:6C:34:22:BD”, “STA_MAC”: “00:22:6C:34:22:BF”, “CountryCode”: “CN”, “CountryRegion”: “1”, “netstat”: “2”, “essid”: “436F687273”, “apcli0”: “192.168.86.106”, “eth2”: “”, “ra0”: “10.10.10.254”, “eth_dhcp”: “1”, “VersionUpdate”: “0”, “NewVer”: “0”, “set_dns_enable”: “1”, “mcu_ver”: “31”, “mcu_ver_new”: “0”, “dsp_ver”: “0”, “dsp_ver_new”: “0”, “date”: “2024:02:23”, “time”: “16:13:14”, “tz”: “-5.0000”, “dst_enable”: “1”, “region”: “unknown”, “prompt_status”: “1”, “iot_ver”: “1.0.0”, “upnp_version”: “1005”, “cap1”: “0x305200”, “capability”: “0x28e90b80”, “languages”: “0x6”, “streams_all”: “0x0”, “streams”: “0x0”, “external”: “0x0”, “plm_support”: “0x2”, “preset_key”: “10”, “spotify_active”: “0”, “lbc_support”: “0”, “privacy_mode”: “0”, “WifiChannel”: “1”, “RSSI”: “-58”, “BSSID”: “F0:72:EA:85:1E:CA”, “battery”: “0”, “battery_percent”: “0”, “securemode”: “1”, “auth”: “WPAPSKWPA2PSK”, “encry”: “AES”, “upnp_uuid”: “uuid:FF31F09E-4766-5A98-16C5-6C70FF31F09E”, “uart_pass_port”: “8899”, “communication_port”: “8819”, “web_firmware_update_hide”: “0”, “ignore_talkstart”: “0”, “web_login_result”: “-1”, “silenceOTATime”: “”, “ignore_silenceOTATime”: “1”, “new_tunein_preset_and_alarm”: “1”, “iheartradio_new”: “1”, “new_iheart_podcast”: “1”, “tidal_version”: “2.0”, “service_version”: “1.0”, “ETH_MAC”: “00:00:00:00:00:00”, “security”: “https/2.0”, “security_version”: “2.0” }
