I am a dentist. I use 3 A50 in my setup at my treatment location. There is one A50 in each treatment room. I’ve got the problem, that sometimes I need very low volumes for conversation. But the lowest volume is even too loud. One step quieter means that it is muted.
I currently use a workaround by using a computer to line-in and level the input volume down by the computers settings, but this forces me to wire the things up, what I can’t do satisfyingly.
I think there are plenty of solutions, however the most important thing is how you want to CONTROL the volume ? E.g. IR Remote control, voice command, a button etc. etc.
I prefer a solution as simple as possible. Voice command is not useful at all in my environment; there are to many uncontrolable noices. A physical interaction is needed. I ve got the Remote control in every room.
I’m happy with the synchrony of the rooms, but I have to adjust the volume in every single room uncomplicated. The output of the A50 is too high. The lowest volume is too loud in some situations.
Hi Christoph,
We actually received such kind of feedback, and we just can’t repeat this issue in office. We’ve tested with 4Ohm speakers, and when set to volume step 1, the output volume is very very low, I need to put my ear onto the speaker to hear the sound.
I’m not sure what speakers you’ve used, maybe it’s very sensitive, so it will have large volume with very low voltage. And for a simple solution, you can try to connect the speakers in serial and see if could solve the issue. Or you can try to add an resistor for example 4Ohm @ 5W in serial with the speaker line to make it not so sensitive, this will also lower the max output volume.
Dear all, when reading this Thread I think I recognize something, but I am not sure.
To me it seems that the volume in the low-volumes still is too loud for Christoph. My guess is that you control the volume of the music by using the A50 remote control volume buttons (or the volume up & down buttons on your smartphone/tablet, or by using the volume slider in Spotify).
Question: is that correct?
I think that you mean to say that when volume = 0 and you move it up 1 step, the volume in some cases is already too loud, and that you prefer to have a volume in between 0 and 1st step.
From my own experience, I have had situations like that with the Up2Stream Mini. Setting the volume via iPhone volume buttons or remote control is then difficult. These operate in 16 steps between 0 and 100% volume. In that case I use the volume slider in the 4Stream App, which is a bit more step-less in setting volume.
If this doesn’t work, I support @zpl1025 's idea. Then it is probably a speaker hardware thing.
@KolfMAKER
It doesn’t matter if I control with RC or app. both are too loud at the lowest possible volume level.
Yes, I need a Volume level between step 0 and 1.
I’m sure it is not a speaker hardware thing. Because I tested each at home with a different speaker setting resulting in the same problem. This occurs with all A50s no matter if they are grouped together or not.
Ok, I get what you mean. You do need a volume step in between 0 and 1.
I also understand that you tried to control the volume with the remote control, but that it’s volume control is in the same steps. So no difference.
Although I have no experience with the A50, it looks like this is the same on the A50 and the Up2Stream Mini. The Mini also has this limitations in volume control. So I also would be prefer to have a better, more finely tuned, control over the volume.
I think you can try to set the max volume of the device, it’s a hidden settings, and you need to set it via API. You can download this debug tool, and then send this command: MCU+PAS+RAKOIT:MXV:50& to set max volume to 50%.
Hi Christoph, i have the same problem as you describe. Look forward to hear simple ideas to fix it. I have a small Nobsound amp that i will try to put in between the loudspeakers and A50. Maybe that works.
My speakers are BW CM5 s2.
With the setting below it is the max for comfortable background music.
I am also wondering if it has to do with the voltage on the power supply.
Hi Rasmus, did you get any clue for this issue? I’ve check the speaker specification, and seems it’s a 8Ohm speaker, which should have not too large volume output. And when you set the larger volume, could you hear any clipping?
If the volume is still too large, maybe you can consider to set max volume with this tool.
I have the exact same thing.
Apparantly there is something like an APC Work Bench that could solve the problem. Anyone used it before?
I talked to ‘Coco’ about this. They want me to write some ‘feedback’ in order to provide a workbench key.
This I find diguisting since I just bought 6 SA100 units.
There is a known problem, there is a solution, but before handing it to you they try to push you in putting positive feedback…
If there is an other solution, please do let me know
Same here, I really want a max volume option in the app, or something. Every company releases this for free because people can get hurt with out a max volume control. Apple is being sued over this as we speak. Im gonna try the APC work bench to set the max volume. If it doesnt work im returning the software.
After upgrade firmware, you should adust the max volume on the WEB UI. Just access with device IP in browser. And if it shows only a loading circle, please try to reset device settings on APP, as the device need to some special work to run a special program on boot.
Hi everyone, I have the same problem with A50. I solved it with the solution provided by zpl1025: in your browser access the IP address of the device (192.168.1.nnn), click on the connect button to connect via the network, then access the settings and change the max-output level ( up to 30% is possible) . Many thanks to @zpl1025, the solution exists even if it is not simple but the support responded by trying to make you purchase the ACPWorkbench Tuning Tool at a cost of $20 when all the other companies provide these settings for free.
Sorry for my bad English, I used an online translator
