i have a multiroom issue for the Up2stream Pro V3 with the newest firmware 4.6.415145.35. App is also in newest Version. Both Up2stream Pro V3 have Default settings.
I have two Up2stream Pro V3 . One has the spdif out extension Board connected and the other one has the DAC Extension Board and the volume control knob connected.
If i connect them in multiroom mode, the one with the DAC has a defect volume control. If the Volume is off, both audio output are silence but If i raise the volume a bit (for both or single up2stream pro v3), the Up2stream with the DAC outputs 100% volume. The other one works as expected and has a regulated volume.
In normal mode (no mutliroom) everything works fine on both.
For me i cannot use them in mutliroom mode at the moment. Maybe this is already a known issue for the newest firmware? Also tried to restore factory settings. But this did not help.
Here are the internal informations:
The one bis DAC and volume knob
“uuid”: “FF31F09EA1895486EE09DB31”,
“DeviceName”: “Küche”,
“GroupName”: “Küche”,
“ssid”: “Küche_4AAE”,
“language”: “en_us”,
“firmware”: “4.6.415145”,
“hardware”: “A31”,
“build”: “release”,
“project”: “UP2STREAM_PRO_V3”,
“priv_prj”: “UP2STREAM_PRO_V3”,
“project_build_name”: “a31rakoit”,
“Release”: “20220427”,
“temp_uuid”: “2EF9241AE8FE897C”,
“hideSSID”: “1”,
“SSIDStrategy”: “2”,
“branch”: “A31_stable_4.6”,
“group”: “0”,
“wmrm_version”: “4.2”,
“internet”: “1”,
“MAC”: “00:22:6C:1D:4A:AE”,
“STA_MAC”: “00:22:6C:1D:4A:B0”,
“CountryCode”: “CN”,
“CountryRegion”: “1”,
“netstat”: “2”,
“essid”: “7468652E6E6574”,
“apcli0”: “192.168.0.168”,
“eth2”: “”,
“ra0”: “10.10.10.254”,
“eth_dhcp”: “1”,
“VersionUpdate”: “0”,
“NewVer”: “0”,
“set_dns_enable”: “1”,
“mcu_ver”: “35”,
“mcu_ver_new”: “0”,
“dsp_ver”: “0”,
“dsp_ver_new”: “0”,
“date”: “2022:09:02”,
“time”: “08:09:20”,
“tz”: “1.0000”,
“dst_enable”: “1”,
“region”: “unknown”,
“prompt_status”: “1”,
“iot_ver”: “1.0.0”,
“upnp_version”: “1005”,
“cap1”: “0x305200”,
“capability”: “0x28e90b80”,
“languages”: “0x6”,
“streams_all”: “0x7bff7ffe”,
“streams”: “0x7b9831fe”,
“external”: “0x0”,
“plm_support”: “0x8006”,
“preset_key”: “10”,
“spotify_active”: “0”,
“lbc_support”: “0”,
“privacy_mode”: “0”,
“WifiChannel”: “5”,
“RSSI”: “-46”,
“BSSID”: “F4:92:BF:14:34:EC”,
“battery”: “0”,
“battery_percent”: “0”,
“securemode”: “1”,
“auth”: “WPAPSKWPA2PSK”,
“encry”: “AES”,
“upnp_uuid”: “uuid:FF31F09E-A189-5486-EE09-DB31FF31F09E”,
“uart_pass_port”: “8899”,
“communication_port”: “8819”,
“web_firmware_update_hide”: “0”,
“ignore_talkstart”: “0”,
“web_login_result”: “-1”,
“silenceOTATime”: “”,
“ignore_silenceOTATime”: “1”,
“new_tunein_preset_and_alarm”: “1”,
“iheartradio_new”: “1”,
“new_iheart_podcast”: “1”,
“tidal_version”: “2.0”,
“service_version”: “1.0”,
“ETH_MAC”: “00:00:00:00:00:00”,
“security”: “https/2.0”,
“security_version”: “2.0”
The one with the spdif output
“uuid”: “FF31F09E3727486B74A5BC19”,
“DeviceName”: “Wohnzimmer”,
“GroupName”: “Wohnzimmer”,
“ssid”: “SoundSystem_375E”,
“hardware”: “A31”,
“build”: “release”,
“temp_uuid”: “66E2938CF44BBF16”,
“hideSSID”: “1”,
“group”: “0”,
“internet”: “1”,
“MAC”: “00:22:6C:1D:37:5E”,
“STA_MAC”: “00:22:6C:1D:37:60”,
“netstat”: “2”,
“apcli0”: “192.168.0.166”,
“eth2”: “”,
“eth_dhcp”: “1”,
“NewVer”: “0”,
“mcu_ver”: “35”,
“mcu_ver_new”: “0”,
“dsp_ver”: “0”,
“dsp_ver_new”: “0”,
“time”: “08:11:11”,
“tz”: “1.0000”,
“dst_enable”: “1”,
“iot_ver”: “1.0.0”,
“cap1”: “0x305200”,
“languages”: “0x6”,
“external”: “0x0”,
“preset_key”: “10”,
“lbc_support”: “0”,
“WifiChannel”: “5”,
“RSSI”: “-52”,
“BSSID”: “68:D7:9A:81:AF:FC”,
“battery”: “0”,
“securemode”: “1”,
“encry”: “AES”,
“upnp_uuid”: “uuid:FF31F09E-3727-486B-74A5-BC19FF31F09E”,
