I bought two plate amps for designing a 2-way stereo system i.e. using a plate amp for each channel and designing a filter network as crossover.
After that it became obvious to me that this seems to be not the way these amps are designed for?
Before sinking another 20$ for the ACPWorkbench, can someone clearify if it is possible:
- to use a plateamp for a two way box, one channel for the tweeter, one channel for Bass, i.e. digital crossover (I’m sure that might be possible with ACPWorkbench)
- to define one plateamp as the left stereo channel and one as right stereo channel?
- to link the two plateamps to act as a stereo system?
- What typ of connector is the internal speaker cable, as I need a second one for the second internal speaker.
Thank you!
