I recently bought a SPDIF Output board for outputting audio signals from my 2.1 Amp to an additional soundbar. Now I decided to change the setup and want to use the SPDIF Output Board as input but can’t get it to work. I have already set the SPDIF Pin as Input in ACPWorkbench.
Is that possible or do I have to buy the Input board. If yes, what is the difference between those two boards?
BTW, the white text (silkscreen) on the 2 pin power header of the 2.1 Amp is wrong. The +5V and GND Pins are swapped. But connecting them with the cable to an extension board makes it correct, fortunately.
Best Regards
TJ1999
