I have an audio device (RPi3 with moOde Audio) which detects the BP50 in DAC mode perfectly fine.
However, if I switch to HDMI ARC input for some movie entertainment, then later back to DAC for music, the RPi/moOde plays no sound.
To be fair, I think it’s the RPi or moOde that should detect USB out/in events and refresh its audio output, but before I start DIY’ing solutions there, I want to ask if this is familiar and easily solvable on the BP50 side, say with an update or setting.
After a lot of web searches I managed to narrow the scope toward mpd and alsa, and finally figured out that the device mappings work just fine - but the RPi ALSA mixer volume is set to zero when the device is added.
This is not a BP50 issue, but I’ll leave this here in case others run into the same. The solution was to add an entry on the RPi host which runs a tiny script that uses amixer to set volume to 100%.
Finding the USB device identifier: use udevadm to locate the correct device under /dev/snd/ and examine:
> udevadm info -q path -n /dev/snd/pcmC2D0p
/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.0/sound/card2
> udevadm info -a -p /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.0/sound/card2/pcmC2D0p >dev_info.txt
In the output, locate the first idProduct/idVendor in the chain:
