scohrss
December 17, 2024, 4:58pm
1
How you set up and use Foobar requires you to add a UPnP component .
How do you do that for the Arylic Device?
After that is done, it seems you can add the new component to Foobar to play your media via Arylic.
Anybody tried this? Tips. I cant find any help anywhere?
This may help me:
How to play from Windows PC via Foobar2000 Our devices support UpNP protocol, with the popular foobar2000, you can play music from Windows PC to our devices. Please follow the steps below: download the foobar2000 and install it. 2- download the UpNP...
Steve1
December 20, 2024, 3:59am
2
I have been using Foobar for 3 or 4 years now with no issues, the link you require for the plugin is here foobar2000: Components Repository - UPnP/DLNA Renderer, Server, Control Point
ozgur
December 28, 2024, 7:10am
3
It works like charm… No problem…
Tony
January 2, 2025, 8:53pm
4
My problem is that in Foobar the Upnp component does not turn gray and it seems not to work and in Music Bee the acrylic sever does not appear as an option. Contrary in Spotify connects fine. Any suggestions ?
Have you installed the plugin?
Tony
January 3, 2025, 7:28pm
6
By plugin you mean the UPNP component renderer ?
Tony
January 4, 2025, 9:50am
7
For some mysterious reasons foobar sees the system. So thanks and everything is solved
