Hello everyone,
Did someone manage to connect the SPDIF Input board with the Up2Sream Pro V4
For me is not working ?
FW 4.6.415145.35
Any Ideeas ?
Thanks
Hello everyone,
FW 4.6.415145.35
Any Ideeas ?
Thanks
Hi dobritz,
You need to change the configuration with the ACP tool software, go to the second tab (Audio Effect) Look for PIN: SPDIF in the end, and then choose SPDIF IN, (default is SPDIF OUT), you then need to Save Configuration To Flash, you will find it in Downloader menu on top.
You need to do a factory reset on APP to take effect
Hello @Steve1 , tryed that already, but isn’t working. Does the any check led, something to see if it’s working ? same problem with Up2Stream Mini
Thanks !
I’m having this problem as well. After hitting “save configuration to flash”, the unit kind of disconnects from ACPWorkbench for just a couple of seconds, and when it comes back and refreshes, the setting is back to “OUT”.
@zpl1025 Frank, can you please provide some input here?
Thanks
strange, I should have checked this many times. It should work, I’ll check this issue.
The board is Up2Stream PRO V4, right?
A couple of years past this and I’m still searching for an answer…
