Up2Stream Pro V3 SPDIF and ACP workbench
I’m new to the forum but have been using Arylic Up2Stream Pro V2 boards for a few years. Just purchased two V3 boards (no amp) and I used the ACP workbench to toggle the SPDIF function pin status from “OUT” to “IN”. The SPDIF pin continues to output coax digital audio just fine no matter which way I set the IN or OUT while connected to ACP Workbench.
Is there another setting in ACP workbench that I must change to make the pin on the V3 board to function as a SPDIF IN? Can’t figure out why the board does nothing when I change the “Out” to “IN”
I don’t need an optical in so I thought I could simply use the pin reconfigured as SPDIF IN on the V3 board rather than buying the SPDIF IN board.
It’s probably not this, but some functions take effect after you save the configuration to the board.
Thanks. I’ll give that a try soon and post my result.
Hi, to switch the SPDIF function, you need to download the settings to flash. And then you need to reset factory on APP to activate the OPT entry on APP. If all goes fine, you should select the OPT on APP to activate the SPDIF IN.
So, setup a fresh board to my wifi > Connect to my PC via USB > Open ACPWorkbench > Masure with REW and setup all the dsp config I want > select SPDIF to IN > export audio settings (always make a backup of settings) > save config to flash > Name it whatever I’d like and set Group Index 1 > the board reboots and when it’s back, SPDIF reads as OUT again.
Wtf? I’ve performed this dance half a dozen times. The darn SPDIF setting keeps getting reset to OUT upon boot.
So, as per suggested, disconnect from PC > go to the app and hit Factory Reset > Set up through the app again > Connect back to the PC and open up ACPWorkbench to find of course it’s forgotten all of the settings we programmed (good thing we saved a local backup), let’s not worry about that for now > set SPDIF pin to IN > Leaving everything stock except for the SPDIF IN setting, save to flash > Assign a “Group Name”, set “Group Index” to 1 and hit OK > the board reboots and when it’s back, SPDIF still reads as OUT.
And all you made me do was delete all my settings. Still no SPDIF in.
