Hi guys,
I have a problem with an Up2Stream Pro that seems to stop playing music after few seconds.
It worked very well for 3 months, integrated in HomeAssistant, but for the last week i cannot use it anymore.
If i play directly from Spotify it stops. If i play from Music assistant or any media card inside HomeAssistant it stops. Also in Music Assistant in wont play at all for the last 3-4 days, and i have a “status-like” : external source active: USB_DAC and no movement.
When it stops, the red led is on for few seconds and back to white.
I tried resetting the device, factory reset, i’ve reset all i can think of in Home Assistant, and same thing happens.
Does anyone have any idea of what is going on ?
Thanks in advance.
I have a similar problem. I have tried messaging Arylic but got no response. Did you get your issue resolved?
Hi Charliepapa, I’m having the same issue.
Did you get to the bottom of this?
Hi, from your description, I think the USBDAC mode is wrongly activated, could you check the connection cable? or try with another adaptor.
The same problem.
