Up2Stream Pro: Multiple outputs?
Hello
I’m running a system with a Up2Stream Pro feed by USB from a PC and then sending the signal via I2S to an amplifier board with DSP.
Now are I considering to add one (or more) subbas to the same room.
Can I connect the Up2Stream Amp mono to the Up2Stream Pro wireless without and kind of time delay?
I see some potential solution, don’t know if any of them works:
  • I2S + BT
  • I2S + Wifi
  • I2S + USB (host)
  • I2S + Line out
Priority one are to have the Up2Stream Pro + Up2Stream Amp in sync (minimum time delay)
Second priority would be to have it in wireless
Third priority are any kind of connection as long as there are no time delay.
Are there any kind of DSP in the Up2Stream Amp?
Minimum do I need a Low pass filter. It would also be great if it has basshelf or similar filters.
