Hi.
Does anyone know how i can make the left and right channel have sepperate filter/crossover for a 2 way speaker?
I would like to connect left and right channel to 2 sepperate amplifier boards and have the first amplifier power the woofer and the second amplifier power the tweeter.
I’ve brought 6 of these boards… So I will really like to get it working
Thanks you
I did it on the Up2Stream Amp 2.1, with the usage of ACPWorkbench tool (on PC) to set different filters on the left & right channel. I’m not sure if the same filters per channel are possible with the Mini v3.
I cut the bass at 170 Hz on the boomer (right channel) because on the Amp 2.1 there is a sub woofer to take those low frequencies.
I have put 2 high pass filters (and not one), on the left channel (Tweeter) to be sure that my sensitive ribbon twitter doesnt take too much residual bass. It’s not a must.
May be you need first to upgrade your board to the latest firmware: when I recieved my Amp 2.1 board few monthes ago, this option of left & right channel filters was not appearing on the ACP workbench. It appeared after the upgrade of the board to version 4.2.9326.26
