I have an Up2Stream Mini that suddenly is not able to re-connect with the WiFi network of my FRITZ!BoX 7590 JX. It has been connected with the FRITZ!Box for 6 months without any problem. But suddenly it lost connection and now I am not able to re-connect again.
Things tried, but didn’t work:
- On the router I am using the 2.4Ghz
- Encryption is set to (only) WPA2
- I have reset the Mini and tried to re-install it.
- I have set the WiFi to a different channel.
- I set my iPhone as a hotspot, but also my iPhones hotspot SSID did not show up in the list of available WiFi networks.
- I tried the WiiM App, it did recognize the Mini, but also failed in showing the WiFi SSID to connect to. Manually adding that also did not work.
One of the issues of the install procedure with 4Stream, is that in the step of connecting to the WiFi network, 4Stream does not show the SSID of my router in the list. If I put it in manually, it tries connecting but in the end fails.
What I also saw was that when 4Stream App tries to connect the Mini to the WiFi, it says ‘Connecting (null) to WiFi’. I think this means that 4Stream App did not pick up a correct SSID of the WiFi network. While the SSID does no show in 4Stream, it does on my iPhone, and my iPhone is able to connect.
Question
- What can I do to solve this?
FRITZ!Box 5790 JX picture:
