I have connected the I2S output of a Up2Stream to a ADAU1701 DSP. If I stream audio over the WiFi or Ethernet, only the right channel creates heavy distortion. This issue doesn’t appear if I stream audio over bluetooth, USB or analog input. If I switch the LRCLK the distortion comes only from the left channel.
Also the automatic voice, which tells me that the WiFi connection is connected, is distorted. I think it’s related to the Linkplay board. I tried another Up2Stream but get the same result.
HI,
I have had no distortion using two different I2S Dacs or using the SPDIF as Coax with the Mini V3.
I suspect that your wiring may have a break in the harness causing issues especially if the wiring is multi strand rather than solid Core. Alternatively it might be a power issue.
Are you feeding power in Via USB only as the Mini may have current issues feeding an attached DAC. IF so you need to supply 1A or above at 5v to the separate power connector (no need of the usb connection for power)
I checked the cable four times, cut it, soldered it new. Always the same problem. And how it could be a cable problem if it only appears with audio via WiFi or Ethernet? Bluetooth over I2S works fine. Also if I use 3,5mm jack connector. If it would be a cable issue, also this signal should be distorted. And how can It switch from left to right depending the LRCLK setting? If I use the Mono mode in the App and use only left channel it works fine. If I use Mono mode for right channel, distorted signal appears on both speakers.
If I use the SPDIF connector also it works fine, but I think it uses the additional extra pin.
I use an exclusive power connection with 5V which can deliver up to 5A via the separate power connector.
Can you make it clearer what works audibly?
Just on its own without the additional Dac is it sounding Ok with no Channel problems with the 3.5mm output?
You said SPDIF was working, is this an optical or coaxial? Are you feeding it to a different Dac?
Do both these outputs show no interference on the L/R channels?
If the interference is only shown with the I2S there is a possibility that the added DAC has a problem especially since you say that it’s the same problem with two Up2Stream units.
I just ran breadboard pin wires between the harness connector to breadboard and then out to Dac plus an RCA connector for SPDIF and didn’t need to change any settings it worked straight away for two different dacs for I2S and a two other dacs for SPDIF.
Ok, sorry, my English is not the best. The I2S output is connected to the Wondom Jab5 (with ADAU1701 onboard). The Jab5 is configured as slave. Now I tried following inputs:
WiFi input and I2S output: has distortion on right channel
Ethernet input and I2S output: has distortion on right channel
Bluetooth input and I2S output: has no distortion
3.5mm Jack analog input and I2S output: has no distortion
The I2S has only distortion if audio is streamed over the Linkplay module - as far as I understood the architecture.
Then I removed the I2S and replace it with the arylic SPDIF/Coax output broad and connect it to my HiFi Amplifier (Technics SU-G700) via Coaxial. In this case everything works fine.
I don‘t have an other DAC with I2S to test. In my opinion nothing is broken. I think it‘s a communication problem. But only with the I2S stream from the Linkplay module. What is the difference between the I2S data stream from Linkplay and the Bluetooth data stream from the Up2Stream board (Bitlength, clock, etc)?
I think your best option is to buy one of the little low cost PCM5102 from Amazon or ebay. Wire it in an see if you have the same problem. That will tell you if your other dac has a problem or not.
The Linkplay will be sending an I2S signal to the onboard dac (the one feeding the amp to the 3.5mm output). That should be the same I2S signal being sent to your DAC.
I find it difficult to understand why the boards own Dac works with the I2S and yours doesn’t, it seems a very strange fault especially when you say the fault is on both boards.
Where does your Dac get its power from? Same supply and Ground as the Up2Stream?
I haven’t downloaded the software for the ACP Workbench; maybe try resetting back to its original settings if you’ve been tweaking the ACP. The I2S was plug and play for me without any changes.
I ask as I have recently purchased the Up2stream mini and connected it to the i2S port of a Wondom AA-AB32256 Amp. Like you, I have good sound quality when I stream from bluetooth, but very heavy distortion when I use the Wifi mode. Also like you, the automatic voice is heavily distorted. Unlike you the distortion is on both channels
I also listened to the line out signal. Again on bluetooth I get good sound, but with Wifi i get heavy distortion. I think this rules out any connection problems between the Up2stream board and the Wondom amp.
No. I bought one of the PCM5102 boards. With this board everything works fine. From Wondom support I got the info that the JAB5 expect 48kHz with 24Bit by default. As I remember I changed it with Sigma Studio, but I’m not sure. I paused the project until I have mmore time.
I do not know about Mini, but ampv4 is in master mode
I know JAB3 is in master mode too, and to switch to slave mode you have do remove oscillator and connect pin to i2s from up2stream.
maybe you have same problem
This is not needed with the JAB5 because it has onboard ADU1701 with I2S input by default. JAB5 has to be switched in Slave Mode. This can be done by a switch. Not sure how other Amplifier modules work, like the Wondom AA-AB32256.
Not sure what you mean with »Micro Switch«. It has an Switch to switch between Master and Slave Mode. And it’s well documented, that you have to set Slave-Mode if you are using I2S. And as mentioned in the beginning of this thread, the problem only appears on network (WiFi and Ethernet) streaming and not on bluetooth (and SPDIF) connections.
Now I found time to try out your solution, but it doesn‘t solve the problem. Still only the right channel is distorted vie Network connections. The only solution that works is, to place the Arylic S/PDIF output board and the WM8804 board between the Up2Stream.
Pity that the simple (and cheap) solution did not work for you, but it’s good that you managed to find a way to get it to work.
I have since extended the buffer idea and turned it into an I2S multiplexer (needed for my project) and still do not get any distortion (if you’re interested you can find the details here) .
My hypothesis is that the tolerances of the I2S signal drive current supplied by the Up2Stream and the input load capacitance of the WONDOM amp are causing the problem. A drive current at the low end of the tolerance from the Up2Stream and a load capacitance at the high end of the tolerance for the WONDOM amp could result in a mistiming of the I2S signals leading to distortion. In my case, it could be that the drive-current/load-capacitance ratio on both chanels was enough to cause the mistiming, but could be adjusted by using the SN74HC126. In your case the ratio was maybe “worse” on one channel only and the WM8804 had enough drive current to get round the problem. My reading of the specs for both devices didn’t really throw light on the matter.
But as we all know, “hypothesis” is just a fancy word for “guess”, and without more engineering skills from my side and test equpiment is still remains that - a guess. Secondly, if you’re like me, you’re just happy that you’ve got something that works.
Yes, finding the right solution is just a guess without support from both manufacture. I can live with my solution and I will not invest more time to find a better solution. But in generell I‘m not happy because a workaround it‘s just a workaround. My dream was an easy and slick solution - Up2Stream to Wondom JAB5 and nothing more.
Your multiplexer is a great project but not for my needs. But never knows. Thanks
