Up2Stream HD DAC, turn-off function doesn't work
Hi all,
Recently I bought a Up2Stream HD DAC with discounted price :grin:
It’s a really good player if you consider its price level. 9038q2m is a great DAC and airplay2, aptx, dlna, upnp, multiroom supports etc… make it invaluable… Sound is smooth and musical, distortion free, stage is wide, tonal balance is great… Except it has a little noise on the outputs, however its acceptaple for this segment…
But;
I have a problem with it, which the power off function doesn’t work, neither on board switch nor remote control. It seems like working when you press the power button; leds or display goes off, output mutes, but after some seconds it resets and boots again…
Does anybody know the solution for this situation? (firmware : 4.6.529755.47)
Happy new year…
I just received my up2stream HD today and I face the same issue. Did you solve your issue ?
No! Added apower switch to power line… :frowning:
