Up2Stream HD DAC firmware upgrade and 'debugging'.
hi,
I’ve an Up2Stream HD DAC with firmware version 4.6.509530.45 indicated by the phone app date 20230302. It seems according to Arylic’s pages that the current fw would be 4.6.415145.35 ??? 4 questions:
  1. what is the correct fw?
  2. where to download it (firmware download section in the support pages just disappeared)?
  3. I’ve got from Arylics support a long time ago a 4stream phone app patch v. 3.1.18.230210 to connect to Qobuz, but standard audio resolution files (44.1khz, 16bits) are not read correctly numerous drops out in the restitution which doesn’t occur with high res files. Is there a better combination (board firmware/phone app) available for te HD DAC as it seems, the HD DAC is from a very different design (linkplay board -A98 -, api etc) as the other arylic’s devices.
  4. I’ve found the UART command file apparently for the HD DAC too, how to send the commands to the HD board, as the web interface doesn’t exist?
    Thanks a lot for your support
    N.
