For this project, I used the Up2Stream Amp along with walnut wood to create a unique housing for my Up2Stream Amp. I wanted to design something that would match or look great on my workdesk.
I’m using the Up2Streamboard as the sound card for my computer, as well as for internet radio streaming and Bluetooth connection with my TV. Everything works perfectly. The buttons on the front panel are set up for preset internet radio stations, so I can quickly choose what to listen to without needing to open the app on my phone or PC.
The shell was made using a CNC machine, while the back panel was 3D printed. I included plenty of ventilation space for airflow and also added an IR receiver to improve signal reception from the remote.
