Hi All!
I bought a Up2Stream AMP 2.1 and i would like to use it also as an Alexa Cast device.
Is there a software trick to use an Up2Stream AMP 2.1 this way?
I didn’t find a skill to achieve this.
Thanks in advance!
PH
Hi All!
Thanks in advance!
PH
They don’t even have chromecast support. You think they’re going to have Amazon support? Please.
Your best bet is to get a discontinued Alexa Input and connect it to the aux in.
