Looking on top of the amp’s connector, I have the LED ground connected to the second pin from left. I have a 1K resistor soldered to the LED leads (except for ground). When I touch the amp’s connector pins with one of the LED color leads, I get the LED to light up. The thing is that switching the amp’s input mode does not seem to change the pin output of the board. For example: When I set the amp to BT, and I have the LED connected to the BT pin, the LED lights up. But when I change the amp’s input source to WIFI the LED is still on, while it should turn of at that point. What am I doing wrong?
Hi Niek,
It looks like you have chosen the wrong type of LED, the type you have is called a ‘Common Cathode’ what you require is a ‘Common Anode’ type to make this work.
Niekos,
The long LED lead (the anode) should have the 1k resistor, this should be connected to the first pin (3.3v) the short leg of the LED (the cathode) connected to the required output pin (ie usb, BT, Line, wifi)
Hi Niekos,
Did you the LEDs to work correctly (either individual LED or common anode LED)? I have been trying to get four individual LEDs to work but it is not quite working. The USB source LED lights when I am not using that source. The in-use will light too??? I would appreciate your input.
There’s something quite wrong with this board and/or its documentation. Completely wrong. I haven’t been able to find the right solution except to solder pins straight to the surface mounted individual LEDs present in the board.
