Has anyone had luck using Tidal Connect on the Up2Stream HD DAC? It’s advertised as being supported, but Tidal absolutely refuses to connect to the device.
I reached out to Arylic for support, but the only help was ‘factory reset and see if it works,’ which it didn’t.
