The option to add streams from my own source to the presets has disappeared from the new 4stream app. Unfortunately, I cannot install the previous version of the 4stream app, and the stream opened from “open network stream” cannot be saved in a preset either. I would be interested in how presets can be edited via httpapi, and how you can memorize your own streams on the buttons of the remote control.
I am answering myself, in the meantime I have tested the problem, newer versions of 4Stream lack the option to save preset own sources - so unfortunately the application only allows saving sources provided by external service providers (and therefore with uncertain access). A temporary solution might be to install an older version of 4Stream while setting up presets (say from https://apkpure.com/4stream/com.wifiaudio.Stream/download/2021091519-APK) (uninstall the latest version first of course) - if you use the remote for daily use, you don’t need to update the app…
