Hi everyone,
I want to use the U2S HD DAC to feed an active sub. I have tested it with just the right aux channel and all woks well. I am worried I might miss some stereolised low range if ignoring the left and would like to sum the L and R aux line levels.
Is it just a case of adding resistors to Y together the L and R?
47kOhm enough or too much?
I have been using line level LFE input. The subs built in filter can filter below whatever comes in from an LFE output device so it does work if I feed it full spectrum signals. So really my question is just about summing uax into mono
