Need a bit of help setting up my Jamo S808 subwoofer to my Arylic A50+. The Jamo sub has a LFE input and low pass setting from 40hz to “LFE”. In this case, I would leave the low pass (hz) to the LFE setting correct? Being that the arylic has low and high pass filtering on the amp? Just need to confirm this, thank you!
I believe the arylic does not have a high pass filter setting. I believe that you should set the low pass filter on the jamo about 15-12Hz above the lowest extension of your speakers
