Hey there, I am using two arylic up2stream mini with toslink board and one amp 2.0.
In some songs that I know how they sound when I stream over Computer app or wired connection with phone sound a little flat over the arylic. Missing a bit of dynamic.
Is there a way to check if the Arclic streaming devices stream in “High Quality” Mode in spotify premium? Sounds to me like the streaming quality is only set to medium in arylic but I have no way to check it.
Hi Eric,
I think the simple answer is no. You could maybe adjust the equalisation settings in the app, but you will probably have to add a DAC board to improve the sound quality.
thanks for your answer. But I think either I dont understand you right or I didnt explain my problem well enough because the second part of your answer makes no sense to me
In Spotify on my phone app and on computer desktop app I can choose in settings the Audio Quality for streaming over wifi, mobile network and download.
I can Choose: automatic, low, normal, high, very high.
In Arylic 4Stream Software or on DSP Tool for amp2.0 I have no option to choose the streaming quality that arylic uses to stream.
You mentioned DAC and Equalizer. Well obviously I use a DAC already because I cannot hear digital, human ear only can hear analoge
My main speakers are powered by two hypex fusion 123 amps and fittingly crossed, EQed and corrected to my room. But I dont understand what this helps with the little slurpy playback from arylic.
Like I said, it sounds like it does not stream in “very high” quality setting. Because when I hook my computer up with the spotify app running on it, it sounds better. More dynamic in complex music, almost no music compression slurping.
Hi Eric,
The digital to analogue conversation within the Arylic mini is embedded within one of the integrated circuits and is of average quality. To improve the sound an external (a separate circuit board) DAC needs to be added.
This is also stated within the Arylic documentation, see snip below.
The highest quality on Spotify is 320kbps. And I’m an audiophile… So I tried Tunelf Spotify Music Converter which helped me get uncompressed Spotify FLAC files and allowed me to change the sample rate and bit rate. Imporatnt to me.
@cc_rain
you know you cannot recreate lossless out of compressed stream?
This helps zero.
@Steve1
my question remains unanswered. I understand what you’re writing, but I just want to know, if arylic streams in “low,medium,high,very high” on spotify. I sounds like medium
The streaming quality on Arylic Spotify Connect is worse than on my PC. I first tested this after i got tired in my ears after a day with my Arylic amp4 streaming via Spotify Connect.
So i tried to connect from my PC via bluetooth to hear if there was a difference and it was to my surprise better that Arylic Spotify wifi streaming.
This also got me thinking same this must be due to the streaming quality settings in Arylic Spotify Connect.
To furter test this i did an A/B test in my main system running Spotify connect in Moode Audio and a Topping D10s connected to the Arylic amp via aux inn, and Spotify connect in Arylic.
Again the difference was clear there was something wrong with the sound quality in Spotify Connect in Arylic.
I was planning to build multiroom speakers for a friend but this sound quality issue with Spotify Connect is a dealbreaker for me.
This is really sad as all the other features of this amp shine and its very easy and flexible to use.
Arylic devs please look into this and see if you find fix
A last question: If its not possible fix this wifi streaming quality issue i am wondering if i can remove the wifi module and reuse only the amp and dsp?
It sounds like the sound quality you’re hearing might not be as dynamic as expected due to the streaming quality. Unfortunately, Arylic devices don’t provide a direct option to check or change the Spotify streaming quality within their app. However, Spotify Premium should automatically stream in the highest quality if the settings are set to “High” or “Very High” in the Spotify app itself.
You can check or change the quality in the Spotify app by:
Opening the app.
Going to Settings > Audio Quality.
Make sure “Very High” is selected for both Wi-Fi and mobile streaming.
As for using a Spotify mod APK, it can give you access to Spotify Premium features like high-quality streaming without an actual Premium account. However, keep in mind that modded apps come with risks, like security issues or potential account bans from Spotify. So, it’s better to stick with the official version for a safe experience!
This is nonesense. You only set the quality for the specific device you’re listening on.
Arylic has its own spotify settings that are just not accessible. As far as I know the streaming happens usually in 256kbits with streamers.
You can download high audio quality of Spotify songs as local files on your computer and phone. As I know, the audio quality of Spotify premium up to 320kbps, if you want to download Spotify music with high audio quality, you can use ViWizard Spotify Music Converter. It will preserve lossless quality when you download Spotify music. In this way, you can enjoy high audio quality of Spotify music on any device.
The streaming quality in Spotify is varified according to your plans. For free users, you will enjoy lower quality, which premium users can enjoy high quality.
So, if you are a Spotify free user and want to listen to high-quality Spotify music, then you can try AudFree Spotify Downloader. It works for both free and premium Spotify users. And all of you can get better listening quality.
I totally get your frustration here. When you sit down for long listening sessions and the sound starts to feel off, it really takes the joy out of the experience. Especially since Spotify Connect should, in theory, give you the same quality as playing directly from your PC. The fact that Bluetooth actually sounded better in your test really says something about how the Arylic module is handling the stream.
Your A/B test with Moode Audio and the Topping D10s was a smart move—it rules out your ears playing tricks on you. If another system using Spotify Connect sounds fine, then it does point to something in Arylic’s implementation. It could be a limitation in the current firmware or even the way the Wi-Fi module processes the stream.
I agree with you that it’s a shame, because Arylic amps are otherwise very practical and flexible. The whole idea of an easy multiroom setup falls apart if the sound quality isn’t right, and I can see why this would stop you from recommending it to a friend. At the end of the day, music gear has to get the sound right first.
As for reusing the amp and DSP without the Wi-Fi module—that’s technically possible, but not always straightforward. You’d likely have to dig into the board, bypass or disable the streaming module, and make sure the rest of the circuitry still runs smoothly. It depends how integrated the Wi-Fi side is with the DSP. If Arylic support can’t fix this via an update, your best bet might be reaching out to them directly to confirm whether the module can be swapped or disabled cleanly.
Hopefully Arylic takes feedback like yours seriously and pushes a fix, because otherwise they’re holding back what could be a really solid little system.
I have noticed a few different issues that show behavior between Spotify app and connect. this is one, and there’s a forum thread from many years ago where people are saying exactly this.
additionally, I looked through some Spotify connect API docs, and there doesn’t seem to be any endpoint or parameter to make any change to the stream quality or bitrate. so it seems we have to chalk this issue up to Spotify and their lack of support to their connect product rather than these Arylic devices.
