Hi, I begun to build my new multiroom audio for the whole house. I am now running and old 6 zone multiroom system from Omnitronic and i will replace it including the button control on the wall in each room.
All the amps (excluding 2pcs in garden) will be in my control room in a rack stand, I plan to have about 10 zones.
I will post here the progress.
Now I am on to produce the face plates for the button board on wall and boxes for the AMP 2.1 that will be used in garden.
Ok my next steps are to build the master unit.
I used an old 4U PC rack case.
Now there are many cables disconnected inside because I need to buy next 4 PCS of AMP2.0 and add it, so i prepared the cables for it. In this time there are 4 AMPs. Temperature switched fans and a LAN switch.
The plan is to have 4pin Speakon output for each AMP
The 8 PCs RJ45 are used for connection of the key boards, XLR connector for line input.
I will add also an cinch input for digital in.
I am still waiting for some components for the main unit. So i made my bathroom now with the AMP 2.1.
I gave to the control button board some water isolation and penetration including shrink foil which is mainly used for remote controls. Hope this will be enough.
There is a subwoofer under the bath tube and small cube speakers on the roof.
The control panel including the AMP board is now under the wash basin furniture.
Ok i tested now to replace the old wall remote to the arylic one.
It’s not perfect but it’s a testing time.
There are old Cat5 cables in the wall, the length is about 30 meters and it works. Cat cable have 8 lines / cable stripes
So it is enough to have buttons, IR and LEDs
That is a great build. You are the first one I’ve seen to use the pin outs. I am about to upgrade my current system to something similar. I feel a bit out of my depth. Would you mind sharing a list of the sockets and connections you used. I really liked your choices for network and speaker out but am also interested in the female sockets you chose to patch into the PCB output.
