I have got an S10, everything works great however the Presets/Favourites are not working for Spotify.
Tried the Android app, ios app and web browser. there is no “save to preset” option… did spotify strip this API from 4stream ?
Currently, many tools are available in the market like SpotifyDown, AudBite Spotify Music Converter, spotify-downloader, etc. They can work to download music files from Spotify for listening anywhere, without limitation to get Premium first or draw Spotify support.
I also encountered the same problem. I found a way to solve this problem. It’s downloading Spotify playlists by a third-party tool, Spotify Music Unlocker.
Currently, there are many Spotify Music Converter tools on the market, you can download Spotify music for listening anytime and anywhere, get Premium first without restrictions, and don’t worry about Spotify platlist not working.
I have an S10, and everything works fine except for the Presets/Favorites on Spotify. I can’t find the “save to preset” option on the Android app, iOS app, or web browser. Did Spotify remove this feature from 4stream, or is it because I’m using Spotify Premium APK?
I’ve just tried this preset feature and seems working fine. And the steps I tested:
1, Play song on Spotify and push to device via Spotify Connect
2, And on 4STREAM APP, show the now playing page, and click the 3 dots to pop a menu and select Preset
3, tap on one of the 10 preset slots, and the playlist will be saved.
4, And switch to another input source, eg: bluetooth
5, and on 4STREAM APP, select Browse tab, and select Preset Content, and tap on the preset to start the playback.
If you’re having trouble with your Spotify playlist or preset not working, it could be due to DRM protection on Spotify music, which can sometimes interfere with usage on certain platforms. A great solution for this is to try DRmare Spotify Music Converter.
This tool lets you download and convert your Spotify playlists to formats like MP3, FLAC, or WAV, making them accessible on any device or platform without restrictions. It’s an easy way to bypass such issues and enjoy your playlists anywhere, anytime!
Hope this helps!
Now, maybe you can try to convert Spotify music for playing on your device without any limits. To do that, you can use AudFree Spotify Music Converter to help you.
Hey! It seems you’re encountering issues with saving Spotify presets on your S10. This is a known problem that some users have reported, particularly when using the 4STREAM app. The “save to preset” option might not be available due to changes in Spotify’s API or limitations within the app itself.
One workaround that has helped some users involves using Spotify Connect:
This method has worked for some users, but it’s not guaranteed to work for everyone.
Additionally, I recently discovered a service called Sociotraffic that offers Monthly Spotify Listeners. I tried it out, and it genuinely helped boost the visibility of my playlists. If you’re looking to increase engagement on your Spotify content, it might be worth exploring.
Hope this helps! Let me know if you have any other questions.
If your Spotify playlist or preset is not working with S10, you can use a professional DRmare Spotify music converter to do format conversion. After that, transferring music downloads to it for playback.
