Hello, when I stream Spotify from my S50 pro or mini-preamps what is then the quality ? On my phone I select highest but what does do the preamps use when connecting to Spotify ? Does it follow my phone request or does it connect always with (High) ?
Just curious since there is no setting in 4STREAM .
Brgds,
Ives
The streaming settings provided in your spotify application will be used. If in the wifi settings you select the best quality, this will be the case on your arylic amplifier.
